Hearing protection for noisy tractors. Worktunes Etc.
   / Hearing protection for noisy tractors. Worktunes Etc. #21
   / Hearing protection for noisy tractors. Worktunes Etc. #22
I dont know if they'll fit a stihl helmet or not. The wire connecting the 2 earcups isnt removable. You could take the helmet suspension out, install the wire with the cups attached, then reinstall the suspension.
If Peltor muffs will fit, then i imagine these could be adapted, carefully... especially considering that these ones were $100 lol.
edit:
Looking at the Stihl website, the "Forestry Helmet System" appears to have the same muffs as mine, minus the radio. The "wire" frame mount for the cups looks very similar. Id say its doable.
Forestry Helmet System - Protective Head & Ear Gear | STIHL
It is not readily doable... I've tried!
We wear either a Stihl/Peltor forestry helmet or a Worktunes headset for all machine use.
I am on my third Worktunes set- the wires connecting the two muffs are fragile and tend to short out after hard use, so the muffs become mono instead of stereo.
Luckily, you can find Worktunes around here for $50 or less (yellow, and without the "Stihl" name- they are identical other than that, as confirmed at Stihl dealer).
I actually wear the full helmet set-up while on the tractor for some jobs (where rough ground might knock my head into the ROPS, or mowing might throw debris into an eye).
Like someone stated, you can use your MP3/Ipod with earbuds underneath those speaker-less muffs.
The forestry helmets last a long time- we have replaced muff components and face screens on them, but not much else.
We trained our kids to wear hearing protection for pretty much anything with a motor (but without a cab).
I know several folks who wore their required hearing protection at work, but ruined their hearing at home through less-than-faithful use of muffs or plugs.
Getting off of soapbox now.
Where was the problem with adapting the worktunes to the stihl helmet? Was the connecting cord too short? Or something else?
   / Hearing protection for noisy tractors. Worktunes Etc. #24
Sounds almost like it was the cheap cord connecting them. If that is the case, some quality time with a soldering iron and some better (longer/heavier) wire would work wonders... I would be willing to try it if anyone has a set that I could experiment on.
Aaron Z
Aaron Z
Id send you mine... but im pretty happy with them as is. :D
I will say the cord isnt the greatest. Its almost like phone cord. The jacket is quite stiff. I can see why it wouldn't hold up to long term abuse
   / Hearing protection for noisy tractors. Worktunes Etc. #26
I guess it's just me, but I can't see putting on ear muffs to cut the noise and then have a radio on which has to overcome the noise that gets through. It seems a little counterproductive. And who wants to listen to the garbage that's on the radio anyway? :thumbdown:
Wow and I thought I was the odd man out thinking this. Glad to know there are other normal people :laughing:. Don't you hate the adverts that seem to scream at you every minute and those "drive time" announcers who think they are funny and witty but are really just plain boring. So to answer the original question I just use heavy duty industrial ear muffs.
   / Hearing protection for noisy tractors. Worktunes Etc. #27
I really like the worktunes, mine have the jack and I just clip one of those tiny ipods to the headphones. Works great until I work longer than I have stuff to listen to loaded then get to repeat it all again:laughing:
   / Hearing protection for noisy tractors. Worktunes Etc. #28
I do almost the same. I have a pair of 'Howard Leight Thunder 29" earmuffs that I put the speakers part of a set of cheap headphones into and I clip an ipod shuffle that i was given (had lost its mind and needed to be wiped) onto the band that goes across the top. Works great for me.
Aaron Z
   / Hearing protection for noisy tractors. Worktunes Etc. #29
I like to listen to the ball game while mowing. It is on a local AM station. I use the AM receiver on my wifes old walk-man. It only comes in when when going in certain directions and blanks out totally in some areas. The station is only 4 miles away ! I would like to get a worktunes but am reluctant to spend the moey because it might not be any better. Does anyone know of one with a good AM receiver ??
gg
378789 (A51572)
378789 (A51572)
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2020 JOHN DEERE 5125R LOT NUMBER 24 (A53084)
2020 JOHN DEERE...
