Business cards
   / Business cards #21
There ate also on line services that you can use for free. Do a search for vector drawing from photo or line drawing from photo.
   / Business cards
Photoshop is definitely not free. And it has a significant learning curve. WAY (way) easier to just have whoever does your cards make your line drawing. It will take you ten hours; it will take them ten minutes.
Mike,
Thanks. That is what I was thinking about I sent the post.
hugs, Brandi
   / Business cards
I went back and found this photo I overlooked. I was looking again for a photo to make a line drawing. I think this will work.
hugs, Brandi
   / Business cards #24
with VistaPrint you can play around and have an image on both sides if you want..
they usually have some kind of special running..
   / Business cards #25
Please do yourself a favor and hire an artist / graphic designer. Your end product will be sooo much more professional! If not at least copy someone else's business card layout. Search for examples online.
Also think about what happens when you trade your red beast for something yellow and heavy!
   / Business cards #26
Although it is possible to convert an image to a line drawing via Photoshop's filters, the results are often much less than pleasing. Don't be surprised or insulted if a graphic designer wants to charge you for an hour or two of work to make a good line drawing out of your original photograph. And don't be surprised if they react poorly to you saying, "Whadda you mean? Just run it thorough that Photoshop thingy." :laughing: ;)
   / Business cards #27
Photoshop is like your tractor. It can do a lot with a skilled operator but it still takes time to do a good job. A business card should take no more than 3hrs. Probably worth $60-75
   / Business cards #28
I've been using photoshop for years...finally got through the first grade. :D
A "real" graphic artist can do a WHOLE lot more.
   / Business cards
Thanks guys for all the ideas. I found a printer in Conroe to look into working with the dragon photo. In the mean time, a good friend down in Houston came through with what I call the first draft. However, I asked her for a revision to remove the wings. So hopefully tonight she has the time to do that.
hugs, Brandi
   / Business cards
I like the way this looks, but the BRB is a 6520, not a 6500.:) I'm pretty sure Photoshop is what my friend is using. Where is Sanger, Texas?
hugs, Brandi
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
New/Unused CFG Industrial QK18R Mini Excavator (A51573)
New/Unused CFG...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
