Welding Up a Cracked Rim
   / Welding Up a Cracked Rim #101
Thanks, its how they did it many years ago on steam engines before there where dyes and chemicals. Still works today.
I'm familiar w/ all sorts of weld specs & weld inspection specs (UP, PT, MT, VT, ad nauseum...) from a NAVSEA world. Never researched 'home' versions of these inspections. Thanks again...
   / Welding Up a Cracked Rim #103
Ever look at the time line when the cracked weld info was divulged? Early on it sounded like another Bubba that rarely drained the air receiver. After the tank bottom was corroded thin, Bubba starts welding the pin holes.
Or is Bubba welding a corroded, thinned out air pressure tank not a problem?
Maybe you should have asked "Bubba" instead of just assuming:confused2:
And even so. If the air tank is already THAT bad, it is unsafe BEFORE "Bubba" starts welding. So what welding he does do, aint gonna make or brake it.
   / Welding Up a Cracked Rim #104
I have welded up many rims with good results.......thats assuming that the crack is beside the bead of the tire....if it makes you feel better you can weld on some chunks of angle iron to make it some stromger.......of course you have to remove the tire first...........if you are a real good welder it may run tubeless
good luck
   / Welding Up a Cracked Rim #105
:D:D:D
Thats too funny.
I wonder how much vibration it "would" have at freeway speed when it is on the trailer and not spinning:laughing:
nd I wonder how much freewy speed ( 45-55mph? ) a tractor tire is gonna see. any partial ounce weld on a rim is likely not gonna be noticeable on a big tractor tire that may have it own knots and bits of lost tread here and there.. or ballast.. plugs.. etc.
soundguy
   / Welding Up a Cracked Rim #106
Bunch of hayseed tractor drivers can make a big deal out of anything. Legend in their own minds
i don't think it's the hayseeds making the problem. the hayseeds ar ethe ones that will just dismount it.. weld it, remount and finish working.
it's the arm chair hand wringers mostly.. :)
   / Welding Up a Cracked Rim #107
Having seen k0ua's posts and talked with him a bit it's easy to see he's not a 'bubba' type...
soundguy
   / Welding Up a Cracked Rim #108
What does this guy say in this video about OSHA and "Experts"? Maybe
we should move this discussion to the comments section of this utube
presentaion and drag this Michelin man into the slingin' all proper like!
So per this guy anyone who said "weld it", well, your not an "expert". ;)
The Penguin thing is absolutely hilarious...:laughing: I literally L'dOL.
Here it is, a scientific recreation of MMH in his coveralls doin' his thing on
a rim w/ the tire on and filled w/ air, just like he implied he wasn't gonna do.
:D
[ame="http://www.youtube.com/watch?v=pNZ4siYGkag&feature=results_video&playnext=1&list=PL3BADECB260018712"]Welding On Truck Wheels - YouTube[/ame]
If indeed it really is an OSHA violation, and we all know OSHA knows all :confused2:,
and if it fails and causes damage and if you tell the world you did it
in a forum your chances of being sue'd, and loosin, are great. Heck if
ANYTHING goes wrong a good (?) attorney could spin your weld into
the reason why the axle broke, which in turn caused the tractor to veer
into your neighbors prized tomata patch doin' 10's of thousands of dollars of damage!
I'M STILL ALIVE!!! One week after the rim weld repair, it still has not exploded. I'm still not brave enough to drive it to school and risk having it explode there killing hundreds of chitlins in the process...
   / Welding Up a Cracked Rim #110
:thumbsup: Thanks for the update :laughing:
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
Polaris Side by Side (A50324)
Polaris Side by...
2008 Nissan Sentra Passenger Car (A51694)
2008 Nissan Sentra...
2006 S&H HORSE TRAILER (A52472)
2006 S&H HORSE...
43030 (A51691)
43030 (A51691)
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
