1026R or 2520 having a tough time
/ 1026R or 2520 having a tough time
I do commercial work with a 1026r tlb. When I have big jobs I rent a track loader or mini excavator. I could make the argument that a 3320 is too light for dirt work. Get what you will use most. Buy the features that make your life easier. Don't worry if it's small. You'll have just as much fun with it. For me the extra $4k to upgrade to a worse mower with an old fashioned backhoe that had to be removed to use the mower was a deal breaker.
Btw: all cuts are too light for dirt work but it doesn't stop me! Hahahahaha!
Do you use your 1026r TLB on removing stumps at all? Do you have experience with 2 series or 3 series backhoes? If so how much less capable is the 1 series backhoe?
/ 1026R or 2520 having a tough time #22
I don't have any experiences with the other hoes.
I can tell you the 17d mini ex isn't a lot stronger than the 260 hoe so I wouldn't imagine the others would be dramatically different. I'm sure they are stronger but not more than twice as much. I have dug stumps up to 16" diameter measured at 2 ft above the ground with the 260. It took me 7 hours and my truck to help pull it out.
Any stumps for shrubs, brush, or trees less than 6" in diameter are easy and can be pulled in minutes. The 1026 is a landscaping machine, not land clearing. That being said, I have used it with a chainsaw and bush hog to clear land in tight spots.
It's like having a mini skid steer. They have their place but don't substitute for the full size machine.
If you aren't in a rush they can do anything. They sure beat beasts of burden!
I didn't notice a big difference in power until I rented the 27d mini ex. That's where excavators start earning their reputation.
/ 1026R or 2520 having a tough time #23
So Barry,
Have you ordered a tractor yet? If not, don't forget to check out the MAX at Foote tractor (just to add to the confusion some).
/ 1026R or 2520 having a tough time #24
I use the x749 with 3PH and rear pto for landscape work in close quarters and the 110tlb and 4520 where there is enough room. This covers 90% of the work I do, the rest I hire out, as it would be hard to justify buying equipment that isn't needed for everyday work.
I would guess that the new 1026R would be a good choice for the small jobs and mowing a lawn. Dirt moving and other ground engaging jobs will be much better with heavier equipment, depending on the job to do the sky is the limit. Good luck with your business.
So Barry,
not yet....still waitng and thinking about what I want to do. Im headed up to wolverine in Ann arbor and I think I may rent a BX25 TLB for the day and see how I like the subcompact sized tractor. Unless you know somewhere else around that rents subcompact sized Kubotas or JDs? I will be honest Im not impressed with either Foote tractor store. When I went in there I felt like the guys wouldnt spend anytime to help me....made me a little mad and they werent all that helpful.
/ 1026R or 2520 having a tough time #26
I bought from a deere dealer further away because I didn't like the salesman at the local shop. Kind of a pita, but I felt llike I owed it to him after he spent so much time with me.
/ 1026R or 2520 having a tough time #27
So Barry,
Have you been to Boullion sales? They were way nicer to me than D&G, better pricing too. I've only rented from CAT Novi before, so I'm unfamiliar with places that rent residential equipment.
So Barry,
Yes I spoke with I believe Phil Boullion there. I wish I could say I will buy from D&G as they are 5 minutes from my house but im not 100% sold on the sales guy there either. I have bought both chain saws, weed eater, and leaf blower there also......basically now its not if I get a tractor, its what tractor do I want.....once I get there I will then go to the place that gives the best deal. Im also still not sure if I want a backhoe or not.
/ 1026R or 2520 having a tough time #29
Id also encourage you to visit the service Dept. The salesman matters much less after the sale, but can be helpful for warranty work. I like my service guys a lot.
/ 1026R or 2520 having a tough time #30
Barry,
The smaller 1026R should do everything you need to do including running a small 3PH chipper. I say that because the x700 series will do it, recognize once you clean up the place there won't be much left to do but mowing and snow clearing. In your shoes I would go with the 1026R and auto connect deck. If you are mowing you would remove the loader, so disconnecting the lines is a non issue.
About the implements, you can buy most of the stuff on your list for the difference in price between a 1026R and a 2520. Don't see the need for the brushhog for an acre that you are clearing and cleaning up, The auto connect deck will do all the mowing you need to do. Something not mentioned is the fact that you could buy a couple of pto drive lines for your Dad's pto equipment and swap them out easily when using a different tractor. That would be alot more cost effective solution.
With my x749 I do more utility work than mowing so far and have several implements to use with the 3PH. Thhis includes a DR chipper, 5' landscape rake, 4' boxblade, 5' rear blade, 4' landplane grader, 6' pine needle rake, Howard HR4 5' tiller and a one row cultivator. I also have various pull type implements, MC519 collection cart, spin spreaders, drop spreaders, steel carts and a lawn roller. Just saying if a x700 series will work for all of these attachments then a 1026R with the extras such as a fel, mmm and backhoe that are all quick connect should work out great for you. The auto connect features are key here, this and an IMatch makes changing implements out fun by comparison.
The 2520 is a great little tractor too and would be better if you need the extra ground clearance. My only issue with the 2520 is once you clean up the acre you have then all you really need is a riding mower and that sounds like the 1026R will be more than you need.
/ 1026R or 2520 having a tough time #31
Barry,
Hello,
I'm shopping for a compact tractor, FEL, front snowblower (ï½*~54'') and maybe a mower (depending the size of the tractor). I tried a JD 1026r and it seems to be a great tractor (or a great toy). However, I don't want to regret of not buying a bigger tractor. My concern is about the snow blowing capacity and the use of the FEL for light work. Here, we have a fews big storm in winter (more than 15 inch of snow).
I use frequently a Kubota L2850. It's a nice tractor but the agressive tires with calcium are domageable for the lawn. I like to use the FEL in the snow but I don't like to blow in reverse (it's painful for the neck). And I think that HST is a plus.
I want to know what I can expect from the 1026r and if it's better to go with a 2520 or a orange B2620. I prefer the 1026r to the BX
Regards,
/ 1026R or 2520 having a tough time #32
Hello,
Regards,
You might consider having two sets of tires and wheels, one turf set for mowing and another set R4 or R1 loaded. This way you can pick a tractor that will fill most of your needs. This would seem to work if in the mowing season you don't have alot of ground engaging and heavy fel jobs. You might also consider wheel weights and chains for winter use as turfs work well this way.
I really prefer to have the mower as light as possible and the tractor with fel heavy, so that doesn't work well in one machine. If you can swing it having a light mower and a heavy tractor/fel combination would be best. Obviously the real issue is the fel requires alot of ballast and rear counterweight if you didn't need the fel then one machine from a garden tractor to a 30 hp machine could deal with a front blower and a rearblade, remove the attachments and you can have a light mowing tractor.
/ 1026R or 2520 having a tough time #33
What I learned. I have been mowing my lawn with a 2305 with loaded R4 tires and the FEL removed for years. I decided to plant some shrubs this year so I put on the backhoe. What a difference as far as easily tearing up the lawn. Moving around was painful as any sharp turn would tear things up. After reading on here how people mow with much larger machines which must weigh the same as mine with the FEL and Backhoe I have to wonder how. I find the 2305 a compromise I can easily live with. Would I like a larger machine sure but it won't fit into my life.
/ 1026R or 2520 having a tough time #34
Is than a larger tractor as JD 2320 or Kubota B2620 with turf tires R3 will tear up the lawn? I understand that you can't turn tight like a SCUT, there are more weight but this weight is distributed on larger tires.
/ 1026R or 2520 having a tough time #35
Don't understand your first sentence?
About the tires, assuming you have the right tire size for the tractor the type tread patterm will make more difference than physical size and weight. That is how golf courses can use 5xxx machines they have good turf tires with lots of area or footprint.
/ 1026R or 2520 having a tough time #36
Sorry, my question was:
Do you think that a larger tractor as JD 2320 or Kubota B2620 with turf tires R3 will tear up the lawn more than a 1026r with filled R4 tires?
/ 1026R or 2520 having a tough time #38
How about this.
A 2520 with loaded R4's won't be any different as far as "tearing up" than a 1026R with the same. It's common sense with the conditions you cut in,and how good you are with the steering wheel (turning) and how gentle you are with the gas pedals.:)
Greg
/ 1026R or 2520 having a tough time #39
Since the 1026R weighs 400lbs less than the 2520 you will cut up the land a bit less. I've actually used both to mow the same land and the 2520 definitely left a noticeable amount more tread in the lawn. It's not a deal breaker and you can surely mow more carefully to compensate, but there is a difference.
(a pointed out later I should clarify: both had R4s and same-ish pressure. And it really wasn't a deal-breaker, just an improvement)
/ 1026R or 2520 having a tough time #40
I don't think so, I was trying to check the Deere site to determine what options you have for the 2320 turf tires but was unable to log on to the Build your own page.
I have the 26 12 12 hdap tires on my x749 and these are very good for lawn and traction work.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
WATER TRAILER (A58214)
