Will this idea work to backflush a "shallow well" ?
   / Will this idea work to backflush a "shallow well" ? #1
super55
Great North of Michigan
Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
My parents house has a 2" 160' "shallow" well that I would like to see if I can increase the flow rate on. I use the term shallow because it's a 45 year old well that runs off a 3/4 hp shallow well jet pump. The well is artesian and will flow about 3 gal a min on it's own without a pump.
They had an irrigation system installed some years back for the lawn but never really got desired results due to lack of flow rate from the well and I believe the pump may be having issues drawing the water up. I asked my dad if the flow has decreased over the years and he says it's about half of what it used to be. He used to be able to run a single sprinkler off the well alone without any assistance from the pump now it can't even get the rotor head to turn.
I was thinking of trying and backflushing the screen by hooking compressed air and pressurizing the well to force the water back down the well to blow out the sediment from the double screen and since it's artesian it should self prime itself without any troubles.
Has anybody ever done this before or have any advice? In theory I think this may work. I would hate to make a multi-thousand dollar mistake here. So any other ideas or concerns are welcome.
   / Will this idea work to backflush a "shallow well" ? #2
I think you would be better off to rent a 2" gas pump and connect it to the 2" well pipe and try pumping the heck out of it! The gas pumps can have a volume of 25 gpm or more and should help flush it out.
It probably has a problem with sediment and pumping would purge the sediment.
   / Will this idea work to backflush a "shallow well" ? #3
Stim has a good point as the high GPM pumps usually have a bellows set up but remove the check valve to allow the bellows to push/pull like a plunger to clean the screen and debris - since you have postive flow this will rinse the screen off. This would allow the artesian flow to continue but push/pull on the screen more gently than a "fracking" with air.
Your idea to back flush would need a considerable volume of air like a commercial compressor - thats not a bad idea either but it its flowing 3 GPM you will need to do a pressure then release cycle to clean out the screen.
The trash pump with the bellows removed may do the same thing at lower cost.
Unless its really badly plugged I cant see the harm in either method, but it will take some time to clear once you do this.
I really like the idea of utilizing a trash pump as you guys mentioned. My first thought was where I was going to get water from to push back down the pipe but i have a 55 gal. barrel that I could use as a reservoir. The craftsman air compressor I was thinking of initially using can only push 6.2 cfm at 40 psi and then 5.2 at 90. I know I won't get a lot of volume with the compressor but hopefully it will be enough to break any sediment off.
Ok I think I have developed a plan of attack.
1. Hook up trash pump to well on inlet side and attempt to move large volume of water to pick up any debris or sediment that may have passed through the screens but has since settled on the screen tip due to 45 years of use and high iron content.
2. Hook up air compressor to well and frack and bleed well several times to help remove any scale or debris that might be restricting flow from the outside of the screen.
3. Now hook the outlet side of the trash pump to the well and flush tip with a larger amount of water to help move the sediment away from the tip back into the sand.
4. Have a few beers or go golfing to allow time for the sand that may have been pushed away from the screen to move back in.
5. Hook well to inlet side of trash pump and move copious amounts of water to clean out casing one last time before connecting to the household lines.
I think this sounds like a pretty solid OP-Order, Besides this sounds like the perfect excuse for me to tell the wife I need a trash pump.
   / Will this idea work to backflush a "shallow well" ? #5
Could you describe how the well is set up. Ie-- suction pipe size and depth?
Check valve?
Why not pull the suction line.
Consider iron deposits that have scaled off the screen?:)
Check valve?
It's a 2" galv. pipe that is 160' feet deep. That has from what my dad believes is a 4' screen well tip on it much the same you can find at home depot or lowes. There is no suction line inside the well pipe because it is an artesian well and no lifting is necessary. The pipe is then directly reduced to a 1" fitting in order to connect to the 3/4 hp jet pump. There is no check valve in the system as far I know.
I agree with you on the iron deposits. In all reality I really think that is the culprit of the reduced flow. Only problem is the location is 160 feet underground in a naturally pressurized system.
   / Will this idea work to backflush a "shallow well" ? #7
I don't think I would push anything back down the well for fear of contaminating the well or the aquifer.
Another thought that came to me, around here, 20 or so years ago artisan wells had 20' standing head pressure. Because so many wells have been put down that has dropped pressure to zero at times and people think their well has dried up. An honest well company will just sell them a primary well pump. (a lot of artisan wells fill an areator and then pump to the house not using a primary pump)
You might just have a problem with too many wells pulling water from your aquifer. ?????
   / Will this idea work to backflush a "shallow well" ? #8
first of all - are you sure the galvanized pipe didnt corrode to a point where its half size of what it used to be? second, did you pull the foot valve yet and check for sediments? backflushing it thru the pump pipe will hurt the foot valve, after all its designed to keep piped primed. third, an expensive test but did you try using another pipe going into the well and to pump as a test to see if original pipe is closing off?
   / Will this idea work to backflush a "shallow well" ? #9
Interesting ....
Ahhhh .... this I'm familiar with ....
Eight years ago we lost our pump due to iron sedimentation at the bottom of our well (which is not artesian) - the iron had filled the bottom of the well and completely coated the intake of the pump and clogged it up. Burned the pump up.
We had the local water company we buy our softener salt from come out and "bail" the well.
They pulled the pump and used a bailing device (a couple foot long tube, with a flap trapdoor bottom) to pull out all the loose sediment at the well bottom. After doing so and replacing the pump (upgraded from I think a 1/2 HP to 1 HP) we were golden .... for another 8 years ....
I just called them a couple of days ago to come out and do it again, as I noticed that with heavy, continual water usage (washing of the driveway) the well eventually gets to the point where the recovery rate drops off sharply. Cost is around $350 or $400.
What they didn't do the last time was "brush" the well .... as they didn't have the brush or the rig to do it - but they suggested that if after bailing it and running for awhile if there was still a recovery problem, we'd need to contact another company that could "brush" it. Apparently this loosens the iron off the well bore that may be limiting flow into the bore.
This is on a 4" or 5" well that is around 300' or 400' deep, IIRC.
If you have a problem with iron sedimentation at the bottom of the well, then IMO, you probably need to remove the sedimentation to restore performance. I see "backflushing" as a less than ideal solution.
Try Googling "brush and bail" ....
   / Will this idea work to backflush a "shallow well" ? #10
Sounds like dropping a camera would tell the tale.:) they are rentable.
You could drop a spagetti line down to the bottom and acidize?:)
http://activerain.com/image_store/uploads/4/1/8/2/8/ar123147754382814.jpg
I tried to load an image but was unable to get it to attach so the best I could do is post the link of what the well layout is similar too. As far as I know this what the layout is so the well really doesn't have a casing so to speak or a foot valve or check valve. If it does have a casing it is buried somewhere and will have to dig around and look for it.
I know my dad did tell me when the hit the water they had a **** of a time keeping the bore open from so much water flowing out so it might have been a issue where they could only drop a sandpoint down and then the packing to save the well instead of having to plug it. I think the guy that drilled it years ago is still alive and he was friend of my dad when they were younger so it might be better for me to try and do a research with what I got before attempting any repairs.
   / Will this idea work to backflush a "shallow well" ? #12
That's about what I pictured from your descriptions. Just for what it's worth. your sand point apparentlyi is at 160 ft depth. To push water back out of it will take on the order of 80psi just to equal the pressure that is already down there. YOu are talking a serious compressor.
Harry K
   / Will this idea work to backflush a "shallow well" ? #13
I don't think that compressor is big enough to have any real effect. I have a much larger compressor (about 50% higher CFM) and use every bit of it's capacity to blow out irrigation lines (for winterization). Those lines are only 1" and probably 100-120 ft long at the most.
Also, be careful if it's an oil-less compressor -- they are not intended to run continuously. My compressor would try to run continuously if I let it, but I am careful to take breaks between blowing out sprinkler zones, to let it cool down.
I talked to my dad about the well again and cleared up some issues. The well is definitely 2" with a sand tip. Apparently when they pounded it in back in '63 they figured they were going to hit the vein that the neighbors have only 75' away at 40'. After they reached 100' they couldn't get the pipe out so they just kept going deeper and hit water at 160. Then apparently they dropped another screen inside with some type of compression type or cam lock down at the point. Apparently this was pretty typical for the way wells were done in the area almost 50 years ago.
This well was never drilled in it was merely jettied and pounded in so I doubt there is even any packing around the well tip most likely it is just in a sand bed.
Removing/replacing the secondary screen is probably next to impossible as I am sure 50 years of use and corrosion have taken there toll on it.
I don't know if I would be able to get chemicals down the well to break up the sediment since If I can get 3 gal a min flow from a spigot I can only assume that finding removing the cap from the well would give me significantly more flow and possibly issues of getting the cap back on and to seal properly. Besides I would really hate to contaminate the well.
I agree that I doubt my compressor is up to the challenge. I might have to go and rent a trailer compressor. I really like the idea of using a trash pump to back flush the the screens. The high volume/low pressure seems like it might be safer than blasting it and possibly punching a large hole in the screen from corrosion. Only question is I don't know how much water will actually move in the well before everything equalizes from a pump that has a maximum of 40 psi.
Maybe I could rig up some type of fitting and have the local fire dept use there pumper. Than no pressure or volume issues. :D
   / Will this idea work to backflush a "shallow well" ? #15
What is the static pressure at the top of the well? This may determine the type of pump required for back flushing.
What will you use for water supply for back flushing? Will it be contamination free?
Well head: you could place a vertical manifold on it that has tees with valves and a vertical that is full open with a full open valve. A flow thru plug can be used for the installation.:)
I am not sure what the pressure at the well head but there is a spigot within 15 feet of the well and it puts out 3 gpm as for psi I am not sure but I would say it's between 5-8 psi. It is reduced to 1/2" and probably 6 feet higher. I am the cap it has to be less than 10.
backflushing water would be water from the well itself. I would just fill up a 55 gal poly tank that has never had any chemicals in it. Once it went empty I figured I could hook the inlet to the well and pump out debris and once it was clear again fill the resevior back up.
The manifold idea did cross my mind especially after I found this brush called a wirehog designed especially for cleaning wells. I am just not sure how well they would work for cleaning screens and I still have to figure out where the well head is located but best guess is it's 4' underground.
   / Will this idea work to backflush a "shallow well" ? #17
Ok, a manifold is installed and the casing get's the Brush Treatment. What happens to the solid scale that gets knocked off?:)
It falls down to the bottom and gets caught ?? In the screen that was installed in the original well?:)
   / Will this idea work to backflush a "shallow well" ? #18
When living around Wichita KS., set ups like the picture you posted were very common. It was customary to fire a .22 caliber round down the pipe to clear the "sand point". The shock would clear the screens. Never done it myself but can verify it did help on wells that I observed. Not sure how it would work on an artesian well where the water is at the top of the pipe/casing. Another posible option might be to hook up one of those small tanks that set the beads on stubborn tires.
Darn it Egon your right scratch that idea. I don't know if a .22 will work but my brother in-law is EOD in the army. Maybe he could rig me up a depth charge. :thumbsup: The only bead setter we use around here booth is starting fluid.:D
I'll probably just end up trying to back flush it once see if it works and if it doesn't increase flow it's off to Plan B. Which is using what natural flow I do have to fill a 1000gal tank as a reservoir and then set up a completely separate pump system to run the irrigation. At 3 gpm natural flow it will take me 5.5 hours to fill 1000 gallons and that will give me roughly 15-20 minutes in each irrigation zone several times a day if I choose. I was really hoping since the well pushed more water at one time I could get it's flow back but it might be safer not to temp fate and only make things worse and lose flow altogether. The well still adequately meets the demands of the household use but was obviously never intended to meet the demands of an irrigation system. (The pump just can't draw the water fast enough and I don't think stepping up to a 1 hp jet pump will help much) It's going to be at least a month or so before I can even attempt this project but when I do I will do a follow up post as to the results of my endeavor. Until then I'll keep researching away.
   / Will this idea work to backflush a "shallow well" ? #20
How about finding a cheap used 500- 1000 gallon plastic tank and slowly filling it overnight when no one needs to use the water. Then figure out a way to use gravity to water the grass (though it couldn't be applied as evenly as with a sprinkler).
2018 Deere 323E (A53317)
2018 Deere 323E...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
ATHENS PLOW CO. 55-7' DISC HARROW (A60430)
ATHENS PLOW CO...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2372 (A60432)
2372 (A60432)
