Having just completed the disassembly and evaluation of my Massey 135's Delco-Remy 12v generator (more on that later), I wasn't doing much else and I decided to remove the rod bearing caps so I could inspect the rod bearings and crankshaft bearing journals. The rod bearings were in generally good condition, but there were signs of minor scuffing with what appeared to be some material embedded in the bearings, so I'll be replacing the rod bearings after all. Fortunately, the corresponding crankshaft bearing journals were in perfect condition.
One thing led to another, and I decided to go ahead and remove the pistons so I could get a better idea about their condition. I scribed the top of each piston to indicate it's location/orientation and removed the pistons from their cylinders by using the end of a wooden hammer handle pressed against the connecting rod and resting against the crankshaft as a guide, then lightly tapped against the hammer head with my hand. All of the pistons came out easily and appear to be in very good condition, with minimal carbon buildup.
Unfortunately, I'll have to wait to measure the cylinders, because as luck would have it, my bore gauge is nowhere to be found so a new one will have to be ordered tomorrow. If the cylinders all measure within tolerances, I now plan to replace the rings and hone the cylinders.
Change of plans... again.
Since I've gone this far, I may as well go all the way. Soon, I'll be removing the engine so I can complete the engine inspection/overhaul procedures in an engine stand, plus inspect the clutch assembly and change the front transmission seal. Currently, I don't have an engine hoist or engine stand, but fortunately my wife's father has both and is willing to let me borrow them for the duration of my engine rebuild. Previously, removing the engine would have required me to move the tractor so it was positioned under the overhead I beam in my garage so I could use my chain hoist, which would have been a pain to do.
