Noob questions
   / Noob questions #1
hfdff
TX
2001 New Holland TC33, CubCadet gt1554
Here's my Noob question. Is it a good idea to use the FEL to lift up the front end off the the ground to take the wheels off? Besides the obivous saftey issue the only thing I could think of was it would unwanted strain on the tractor frame and FEL arms.
Also, do I need to take the FEL off to jack up the tractor to take one of the tires off?
Thanks for the replies
   / Noob questions #2
I have used a loader for years to jack up the front end of the tractor.. You can point the cutting edge of the loader bucket straight down for maximum lift. then put 2 jackstands under the axle on each side to secure the tractor. I would never put any part of your body in danger with a tractor held by the loader.
James K0UA
   / Noob questions #3
James K0UA
Same here; won't hurt the tractor and is a lot quicker.
   / Noob questions #4
Yes, use the loader, but don't overlook putting jack stands under the axles before you remove a wheel or get under the tractor. Many/most of our tractor's FELs will bleed down slowly over time.
   / Noob questions #5
Agreed, I usually lower mine to rest on the stands so if anything fails nothing gets broken or knocked loose.
   / Noob questions
Thanks for the input. I did place jack stands also to be safe. thanks again.
   / Noob questions #7
While you have it off the ground on the loader grease the front end - kingpins, etc before setting it back down. Lets the grease get into the tight places better.
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58216)
2002 AMERITRAIL...
Deere 410L (A53317)
Deere 410L (A53317)
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
HAND TRUCK, CHAIN & MISC (A58374)
HAND TRUCK, CHAIN...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
