Noob questions
   / Noob questions #1
hfdff
TX
2001 New Holland TC33, CubCadet gt1554
Here's my Noob question. Is it a good idea to use the FEL to lift up the front end off the the ground to take the wheels off? Besides the obivous saftey issue the only thing I could think of was it would unwanted strain on the tractor frame and FEL arms.
Also, do I need to take the FEL off to jack up the tractor to take one of the tires off?
Thanks for the replies
   / Noob questions #2
I have used a loader for years to jack up the front end of the tractor.. You can point the cutting edge of the loader bucket straight down for maximum lift. then put 2 jackstands under the axle on each side to secure the tractor. I would never put any part of your body in danger with a tractor held by the loader.
James K0UA
   / Noob questions #3
James K0UA
Same here; won't hurt the tractor and is a lot quicker.
   / Noob questions #4
Yes, use the loader, but don't overlook putting jack stands under the axles before you remove a wheel or get under the tractor. Many/most of our tractor's FELs will bleed down slowly over time.
   / Noob questions #5
Agreed, I usually lower mine to rest on the stands so if anything fails nothing gets broken or knocked loose.
   / Noob questions
Thanks for the input. I did place jack stands also to be safe. thanks again.
   / Noob questions #7
While you have it off the ground on the loader grease the front end - kingpins, etc before setting it back down. Lets the grease get into the tight places better.
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Galvanized Livestock Gates - (5x Gates) (A55218)
Galvanized...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
Mongo Mover Aluminum Hand Truck (A52377)
Mongo Mover...
