York Rake--Are they any good!
   / York Rake--Are they any good! #11
The scarifier, plus the blade, and crank wheel adjustment are all nice features. I wish I had the scarifier to "till" the ground before raking - thats a great feature especially for soil prep for grass.
With scarifiers ot could sort of double as a box blade but likely not as robust so think of getting a "two in one" tool.
As others said, $800 is a decent price - even if you use it for 5 years it will still be worth $500-600 range with these features.
LANDSCAPE RAKE
The newer York's look to have a spring loaded down pressure rod on the scarifier. This one looks to have some kind of locking rod but don't see any springs. Hoping to take a look at it tomorrow.
Bought it today for $700. Thanks, again, for the support, guys.
   / York Rake--Are they any good! #15
Good for you. I bought less rake(back before the depression:ashamed:) for the same amount.
   / York Rake--Are they any good! #17
You done well,soooo how about some action pics. ;)
York Rakes - YouTube
This will have to do for now:) The 105-110 degrees F here in Kansas kind of puts a damper on outside play.
Edit: I did get a chance to see what the scarifier would do. I figured it should not have any trouble penetrating due to the weight leverage behind. It was a joy to see it cut very smoothly!
   / York Rake--Are they any good! #19
the B9200 is a great machine but a 6 foot york at a 2-3 inch depth might be too much for your old girl. good luck
dick
dick
Now that surprises me as I assumed the B9200 had plenty of stuff to handle a 6' rake.
Would one normally run a rake at that depth? I assume that would have to be in loose dirt as the teeth are probably not strong enough to handle that kind of depth in packed soil.
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
2006 KENTUCKY 53FT  MOVING TRAILER (A57880)
2006 KENTUCKY 53FT...
2019 Freightliner M2 106 Utility Flatbed Day Cab Truck Tractor (A55973)
2019 Freightliner...
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
