Mighty Mule Lock not working
   / Mighty Mule Lock not working #1
zene55
Dripping Springs, TX
Kubota L2800
I have had a mighty mule 350 for a couple of years with no issues. The automatic lock is not unlocking. Any ideas on how to troubleshoot the problem. I was thinking of taking it off and trying to operate it with a 12v battery in the shop.
   / Mighty Mule Lock not working #2
Is that the solenoid type latch? We had trouble with ours because the changing moisture levels in the ground would change the gate geometry just enough between wet/dry seasons to cause the latch to bind. When that happened, I'd just adjust the gate so the latch was in the middle of the slot and not rubbing. That and keeping the latch lubed was all we needed. You might check both issues on your latch.
Seems the latch isn't trying to unlock. No click or anything like before, might just go buy a new one and try that.
   / Mighty Mule Lock not working #4
sounds like a power problem to the latch. have you checked for volatge to it when you hit it? might be a loose or brocken connection or wire between them, usually at the hinge. solonoid might have went out, but unlikely. i would pull the wire off just before the lock and check for power as the first thing. also do you have a full power supply(battery or source) with full power or amperage? solonoids take quite a bit when activated and have you checked the time delay upon startup?
   / Mighty Mule Lock not working #5
yep.. sort out wire issues and make sure hte solenoid is getting signal. if so.. then look for a binding / lube issue
   / Mighty Mule Lock not working #6
Yessir! Before replacing the lock/solenoid, I'd jumper power from an external battery to check its operation. Replacing a solenoid that's not bad because of a broken wire is no fun at all.:)
   / Mighty Mule Lock not working #7
yep..that's the ibm field tech way to fix things. start repalcing parts starting with most expensive till the machine works! :)
   / Mighty Mule Lock not working #8
What are you talking about? I don't see anyone here saying to replace parts till it works but only trying to help with a problem.
   / Mighty Mule Lock not working #9
that comment to jim was actually part of a very old 2 part joke about service techs... the 2nd part is about changing a car tire.. starting on one sid eand going around till you find the flat one (sic) like an imb service tech. IE.. no trouble shooting.. just parts changing :)
but since you asked. post #3 CLEARLY states in no uncertain terms that the OP is thinking about :
I'll guess you missed that part. ;) :)
   / Mighty Mule Lock not working #10
There's no doubt we are over-analyzing this. (That's what we do on TBN.;)) In the first post, Zene55 mentioned taking the solenoid off and testing it with a battery, but in his next post, he seemed to infer that he would just replace it with a new one. I think both Chris and I were suggesting he stick with his original plan, but we could have said it in a lot fewer words.
1995 Rinker Captiva 190 (A55302)
1995 Rinker...
2017 CHEVROLET SONIC (A55745)
2017 CHEVROLET...
2017 New Holland C238 Skidloader (RIDE AND DRIVE) (A50775)
2017 New Holland...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A55302)
2010 Ford F550...
County Line 15 Gallon Sprayer (A54865)
County Line 15...
7046 (A50322)
7046 (A50322)
