Mighty Mule Lock not working
   / Mighty Mule Lock not working #1
zene55
Dripping Springs, TX
Kubota L2800
I have had a mighty mule 350 for a couple of years with no issues. The automatic lock is not unlocking. Any ideas on how to troubleshoot the problem. I was thinking of taking it off and trying to operate it with a 12v battery in the shop.
   / Mighty Mule Lock not working #2
Is that the solenoid type latch? We had trouble with ours because the changing moisture levels in the ground would change the gate geometry just enough between wet/dry seasons to cause the latch to bind. When that happened, I'd just adjust the gate so the latch was in the middle of the slot and not rubbing. That and keeping the latch lubed was all we needed. You might check both issues on your latch.
Seems the latch isn't trying to unlock. No click or anything like before, might just go buy a new one and try that.
   / Mighty Mule Lock not working #4
sounds like a power problem to the latch. have you checked for volatge to it when you hit it? might be a loose or brocken connection or wire between them, usually at the hinge. solonoid might have went out, but unlikely. i would pull the wire off just before the lock and check for power as the first thing. also do you have a full power supply(battery or source) with full power or amperage? solonoids take quite a bit when activated and have you checked the time delay upon startup?
   / Mighty Mule Lock not working #5
yep.. sort out wire issues and make sure hte solenoid is getting signal. if so.. then look for a binding / lube issue
   / Mighty Mule Lock not working #6
Yessir! Before replacing the lock/solenoid, I'd jumper power from an external battery to check its operation. Replacing a solenoid that's not bad because of a broken wire is no fun at all.:)
   / Mighty Mule Lock not working #7
yep..that's the ibm field tech way to fix things. start repalcing parts starting with most expensive till the machine works! :)
   / Mighty Mule Lock not working #8
What are you talking about? I don't see anyone here saying to replace parts till it works but only trying to help with a problem.
   / Mighty Mule Lock not working #9
that comment to jim was actually part of a very old 2 part joke about service techs... the 2nd part is about changing a car tire.. starting on one sid eand going around till you find the flat one (sic) like an imb service tech. IE.. no trouble shooting.. just parts changing :)
but since you asked. post #3 CLEARLY states in no uncertain terms that the OP is thinking about :
I'll guess you missed that part. ;) :)
   / Mighty Mule Lock not working #10
There's no doubt we are over-analyzing this. (That's what we do on TBN.;)) In the first post, Zene55 mentioned taking the solenoid off and testing it with a battery, but in his next post, he seemed to infer that he would just replace it with a new one. I think both Chris and I were suggesting he stick with his original plan, but we could have said it in a lot fewer words.
I sprayed some WD-40 on it and gave it a good tap. Now it seems to be working fine. Thanks for the replys.
   / Mighty Mule Lock not working #12
might want to consider adding some sort of lubricant to it. perhaps a silicone based one. that way it will be lubed.. but not wet and attract dust and dirt.
soundguy
   / Mighty Mule Lock not working #13
Goes to show, "If you can't fix it with a hammer, you have an electrical problem" :thumbsup:
Talked to my brother who has the same gate and he says it came with a circuit to install that keeps the lock open longer. he thinks the lock unlocks and relocks before the gate starts to open. Interesting, I will try and install it this weekend.
   / Mighty Mule Lock not working #15
Back in the day when I was a field service rep for a company that manufactured minicomputers (pre PC days) I carried a box with every circuit board that went into the computer - I called it my "Hero" kit (made me look good when I fixed their problem on the first trip). Sometimes we would just start replacing parts until the unit started working - we called it the "Shotgun" approach. Sometimes after working several hours on a difficult problem that I could not fix I would say a little prayer - Dear Lord please let me get this computer back working only as bad as it was when I first walked in!
   / Mighty Mule Lock not working #16
sounds like an ibm svc tech story! :)
back in the day i used to do some SVC work on WANGS ;) ;)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Honda utv cart (A56859)
Honda utv cart...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
HUSQVARNA RIDING...
UNUSED FUTURE TBL47-47" HYD TELESCOPIC BOOM (A60432)
UNUSED FUTURE...
