Buckgnarly
I wound up using a point below the the ROPS. Also made two brackets to mount the lights. No driling, welding, and no pics!.....yet. Wife has the laptop on trip, have a bunch of stuff already done but no way to post yet.
rrrkkk said:Do what you want, I drilled a 1/4 hole in mine to run the hot wire inside the ROPS, welded a mount for the light and grounded to the ROPS. Why run a wire somewhere else to ground to the frame If a small hole will ruin it it's not worth having.
'probably'.. but why rely upon a painted surface to carry electricity.. if you are running 1 wire.. run 2.. dedicated grounds make for brighter lights and longer bulb life..
