HST slow in reverse (L3800)
   / HST slow in reverse (L3800) #1
Rail Dawg
Got a branch stuck underneath and HST pedal was slightly stuck. All debris removed. Now it's fine moving forward but sluggish in reverse even when pressed firmly down.
Ideas?
Again nothing appears to be binding.
Thanks!!!
Never mind it was a hidden stick doing its best to stop progress! But it was found and it's back to work.
Thanks.
   / HST slow in reverse (L3800) #3
Thanks.
Glad you got it fixed, I saw the post but did not have anything to add except it could be a stick, and you said you cleaned out all the sticks:) glad it was something easy..
James K0UA
James K0UA
Thanks James. I was in the field and it sure is nice to be able to get on here when something goes wrong and get almost instant help.
Take care!
Chuck
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A56438)
2024 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
