New here - Should I care about written specs?
   / New here - Should I care about written specs? #31
I understand your thoughts on reducing lift capacity, but take a moment a review how many places rent JDQA equipped attachments. Then compare that to places that rent skid steer attachments.
My point was - I can find ANY attachment made and since I have the skid steer plate I can use it.
You made the GENERALIZATION towards all Kubotas. MY Kubota can handle ANY skid steer attachment. :) So I was disagreeing with your inclusion of all Kubotas. :)
My generalization is accurate. The quick attach method is SSQA. Period.
By using that method, it opens the door to all kinds of attachments, but at the "cost" of reducing lift capacity. Period.
   / New here - Should I care about written specs? #32
In looking at the John Deere quick attach on our renter's 4610, I really don't how it is any better as to lift capacity than the SSQA on my Kubota, both are out further than a pinned bucket. What am I missing, just curious.
   / New here - Should I care about written specs? #33
The biggest difference is that the SS attachments are heavier duty and therefore heavier. While it's easy to find a set of forks to use, for example, they're heavier than what you would have with a purpose-built set for the Kubota. Additionally, the SSQA frame has a good chunk of weight to it. And this is all weight that you don't have available for the stuff you need to move.
   / New here - Should I care about written specs? #34
I'm going to have to take a closer look at mine as I just don't see these heavy chunks about which you are talking. I will look when I swapped my bucket to pallet forks yesterday and will be putting the bucket back on Thursday or Friday and may drive through the JD lot tomorrow out of curiosity.
   / New here - Should I care about written specs? #35
I don't believe you're going to find a huge amount of weight in the plate. The bigger difference is the weight of the attachment. My 42" forks are under 300 lbs and use the JDQA system. They're #not# SS forks, and that shows in their relatively light weight.
   / New here - Should I care about written specs? #36
When I bought my forks, I had a choice of any weight rating I wanted from light to heavy, 42" or 48". Like I said, maybe I am just missing something as I looked over the 4610 of our renter and just didn't see any significance in material, but obviously didn't weigh anything, so could easily have missed it.
   / New here - Should I care about written specs? #37
I think he is saying that with SSQA you are forced to use skid steer attachments which are heavier built and heavier in weight than compact tractor attachments.
Which is false, because there are tons of SSQA attachments out there made for compact tractors.
   / New here - Should I care about written specs? #38
Thanks, zing went right over my head.
   / New here - Should I care about written specs? #39
That's the point I am making. Your point about lightweight attachments supports my previous comment about being purpose-built for the tractor and thus being lighter weight.
   / New here - Should I care about written specs? #40
And the point I am making is that with a SSQA on a compact tractor you are not forced to use heavy skid steer attachments.
They are also availible in lighter weight purpose built for tractors with the SSQA.
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
Ammco Brake Machine (A55758)
Ammco Brake...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2025 KH72 72in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 KH72 72in...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A57192)
2004 EAGER BEAVER...
