Stump removal with diesel fuel burn
   / Stump removal with diesel fuel burn
20 20 - best advise yet on this one. Can turn out very bad if you aren't careful. Stay away from pine forests on this one.
   / Stump removal with diesel fuel burn #22
My stump is doing a really slow burn. A few rain drops did not help. Yet, it still has a very hot core while the ground around it is normal. First picture is at 24 hour burn time and second is at 48 hours. Still burning. I have to move the ash down to the base so it keeps getting a good source of air.
   / Stump removal with diesel fuel burn #23
Personally, I would have cut that off as close to the ground as possible before lighting the fire... Less wood to burn that way.
Just my $0.02.
Aaron Z
   / Stump removal with diesel fuel burn #24
Just my $0.02.
Aaron Z
You are correct, of course. It was a large stump and I was not motivated to cut it down further. I have another like it and that one I will cut. BTW, the stump is still burning and a bit smaller now but still above ground.
   / Stump removal with diesel fuel burn #25
Not having access to diesel fuel, my father used to use charcoal. Not the least expensive way to go but a lot less smoke in a Suburban setting.
Savage, no way I'd start a fire that close to the house. Time to rent a stump grinder.
About 20 years ago lit off an apple tree stump about 13' from house 5' from deck post.
I had lots of chrushed stone around deck post, but the darn roots burned under ground and post caught on fire.
Chrushed stone just gave it air.
Lucky this happened during day and we were home at the time
   / Stump removal with diesel fuel burn #26
I just tried this method last week. Burned for 30 hours straight, used 2 bags of charcoal along with a fair amount of wood. Result was about 2 inches of stump gone. I have several to remove just around the house. Renting a Vermeer grinder next week. Have a few out on my trails and behind my pole building I was not going to bother with, but since I will have the grinder for 24 hours, gonna do 'em all!
   / Stump removal with diesel fuel burn #27
stumps are real hard to get burning on their own, then real hard to put out.
   / Stump removal with diesel fuel burn #28
I have burned stumps before, and as previously mentioned, it is a slow process and can present a dangerous situation at times. I don't have a BH, but a buddy of mine has an excavator. An excavator can dig out a stump in minutes. I have had large sycamore stumps on my burn pile that burned for 4 days even with it raining at times. I realize that most people don't have access to an excavator, but in regards to my past experiences, this method is a "winning ticket".
UNUSED HURRICANE 6' X 11' CONTAINER (A51248)
UNUSED HURRICANE...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
