Price for used rotary cutter (bush hog)
   / Price for used rotary cutter (bush hog)
http://i1086.photobucket.com/albums/j448/biggreenavalanche/bushhog.jpg
Ok, trying to figure out the photo thing so let me know if this works...
I verified it is actually a 6' so I should be ok as far as my tractor handling it...
made the guy an offer of $600.00, let me know if ya'll think that would be a good price and if he doesn't take it, how high should I go...
I do have a loader so hopefully that can act as a counter balance to the 1200 lb weight....
Rich
   / Price for used rotary cutter (bush hog) #12
the rear wheel looks to be either bent or in need of bearings. If the gearbox is tight and smooth then I would say it is worth $600. I am not familiar with that brand so I don't know how parts availability is- that is one reason I like woods, I can still get just about any part for my attachments.
I paid $165 for my older woods 72-3 at an auction. It was pretty beat up and ugly though. The gearbox was tight, I had to replace seals- the gearbox was full of grease instead of oil so when I put oil it all leaked out overnight. Apparently the previous owner knew that and hence the grease. I straightened out the side rails a little and have been using it. I don't use it a whole lot so I didn't see spending much on it.
   / Price for used rotary cutter (bush hog) #13
What we can see looks pretty good. A new tail wheel or spindle might be needed. A new on probably won't break the bank. A universal(king Kutter,Countryline,Tarter) spindle is only about $30. I suspect it has a more HD version on it. I would feel pretty good going $600 maybe a bit more.
   / Price for used rotary cutter (bush hog) #14
Dragon Products
They are pretty known around here and havent heard one bad thing about them,galv.deck should last you along time. Gearbox would be only thing I would be worried about,can he put on tractor and let you see it run?
I had my old shredder out by road and guy came up said man it looks rough $1400 sounds high does it work, so I got my tractor out and made a pass down and he was counting the cash on the way back. shredder 3.jpg
   / Price for used rotary cutter (bush hog) #15
DEFINITELY worth $600!!! If you can get it for that, buy it!!! If the seller wants a little more, then I still think it would be a good buy, but it just depends on how much more he would need to let it go. Good luck!
Not only will he run it , ive actually used it and seen it in operation...no weird gear box noises I could detect...
   / Price for used rotary cutter (bush hog) #17
650 shredder.jpg This what a $600 dollar shredder usually looks like. Actually there asking $650
   / Price for used rotary cutter (bush hog) #18
700.jpg here's a $700
   / Price for used rotary cutter (bush hog) #20
A buddy of mine just purchased a new Howse 6ft shredder with his tractor and it looked alot heavier duty than there older models,new was somewhere around 1,200/1,300howse cutter.jpg
The shredder I sold was this brand and its still going strong today. If your wondering why I sold it,is because it was a 10ft and I bought a new 8ft so it doesnt hang off the side of my trailer on these tight county roads..
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53472)
Kuhns AE10 Small...
FREIGHTLINER BUCKET TRUCK (A51406)
FREIGHTLINER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
TORO DINGO WALK BEHIND SKID STEER (A51246)
TORO DINGO WALK...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
