Price for used rotary cutter (bush hog)
   / Price for used rotary cutter (bush hog)
http://i1086.photobucket.com/albums/j448/biggreenavalanche/bushhog.jpg
Ok, trying to figure out the photo thing so let me know if this works...
I verified it is actually a 6' so I should be ok as far as my tractor handling it...
made the guy an offer of $600.00, let me know if ya'll think that would be a good price and if he doesn't take it, how high should I go...
I do have a loader so hopefully that can act as a counter balance to the 1200 lb weight....
Rich
   / Price for used rotary cutter (bush hog) #12
the rear wheel looks to be either bent or in need of bearings. If the gearbox is tight and smooth then I would say it is worth $600. I am not familiar with that brand so I don't know how parts availability is- that is one reason I like woods, I can still get just about any part for my attachments.
I paid $165 for my older woods 72-3 at an auction. It was pretty beat up and ugly though. The gearbox was tight, I had to replace seals- the gearbox was full of grease instead of oil so when I put oil it all leaked out overnight. Apparently the previous owner knew that and hence the grease. I straightened out the side rails a little and have been using it. I don't use it a whole lot so I didn't see spending much on it.
   / Price for used rotary cutter (bush hog) #13
What we can see looks pretty good. A new tail wheel or spindle might be needed. A new on probably won't break the bank. A universal(king Kutter,Countryline,Tarter) spindle is only about $30. I suspect it has a more HD version on it. I would feel pretty good going $600 maybe a bit more.
   / Price for used rotary cutter (bush hog) #14
Dragon Products
They are pretty known around here and havent heard one bad thing about them,galv.deck should last you along time. Gearbox would be only thing I would be worried about,can he put on tractor and let you see it run?
I had my old shredder out by road and guy came up said man it looks rough $1400 sounds high does it work, so I got my tractor out and made a pass down and he was counting the cash on the way back. shredder 3.jpg
   / Price for used rotary cutter (bush hog) #15
DEFINITELY worth $600!!! If you can get it for that, buy it!!! If the seller wants a little more, then I still think it would be a good buy, but it just depends on how much more he would need to let it go. Good luck!
Not only will he run it , ive actually used it and seen it in operation...no weird gear box noises I could detect...
   / Price for used rotary cutter (bush hog) #17
650 shredder.jpg This what a $600 dollar shredder usually looks like. Actually there asking $650
   / Price for used rotary cutter (bush hog) #18
700.jpg here's a $700
   / Price for used rotary cutter (bush hog) #20
A buddy of mine just purchased a new Howse 6ft shredder with his tractor and it looked alot heavier duty than there older models,new was somewhere around 1,200/1,300howse cutter.jpg
The shredder I sold was this brand and its still going strong today. If your wondering why I sold it,is because it was a 10ft and I bought a new 8ft so it doesnt hang off the side of my trailer on these tight county roads..
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
