Oil & Fuel farm or road diesel?
   / farm or road diesel? #1
BleedOrange
Jeffersonville, KY
Kubota L3800 4x4 w/loader
Bought a new L3800 back in may of this year and started out with a couple tanks of off road diesel then switched back to road diesel. Don't they recommend using road fuel in the new tractors? Or does it really make much difference? The farm fuel is cheaper and would rather use that, just don't want to affect the warranty. Seems to me though I get more hours from road fuel. Any help would be greatly appreciated! Thanks
   / farm or road diesel? #2
Same,same. Off road has red dye in it and no road tax so you save about 27 cents a gal.
   / farm or road diesel? #3
I have run both in our tractors and couldn't tell any difference, we run farm fuel in all of ours now; go through about $2000 per year and road fuel would eat us up.
   / farm or road diesel? #4
On road and off road fuel are the same product save the dye & tax.
   / farm or road diesel? #5
Thanks, that's what I thought, but wasn't sure.
   / farm or road diesel? #6
No difference but dye where I live.
   / farm or road diesel? #7
Only difference here is $0.40 and color...
   / farm or road diesel? #8
Not trying to start a war here but the two fuels are not the same.....they have similar specs as far as distillation curves, gel temps. and the like but, on road diesel is distilled as a product, cleaned of water and filtered down to less than 25 micron particulates. Off road diesel is a blend of on road diesel that did not make spec. and whatever distilled product it will take to get it on spec., it is then filtered down to less than 70 micron particulates and of course red die is added. Now...these products will do very similar jobs in a tractor, older tractors will benefit from the higher sulfur content of off road diesel while newer tractors have mostly viton seals in the fuel system and they really don't care what type fuel they drink. With the filtering systems on todays machines, I would not be afraid to run off road fuel in one but would not travel too far out of my way to get it either. If it is readily available in your area I say go for it but be sure and change your fuel filters on schedule.
   / farm or road diesel? #9
On road and off road fuel here are both ultra low sulfur.
   / farm or road diesel? #10
My bx2360 has a decal that says ULSD only. The owners manual says if you run offroad diesel you have to change the oil twice as often, once every 50hrs.
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
2021 JOHN DEERE 2032R TRACTOR LOADER BACKHOE 4X4 (A51247)
2021 JOHN DEERE...
RV Hitch (A50121)
RV Hitch (A50121)
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
