Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #1
Marcle
Herefordshire/Gloucestershire boarders UK
Iseki 2140
On the back of my back of my Iseki I have a back actor/hoe that was made by Polymark (sussex) ltd, in the UK. The tractor has only just achieved 200 hours, so the back actor will be less and the tractor came with a rotavator.
Anyway, looking around it over the weekend as I was doing some maintenance checks on it, I noticed someone had done some welding (noticed by fresh non standard paint) on the top link where the main boom/back actor arm joins on to the main frame/assembly. Perhaps this is a weak spot that other owners should watch out for?
Slightly different topic...
I've been looking around the net today to try and find details of the make of hydraulic valve chest used (no luck so far). It would appear Polymark are no longer trading as they seem to have been taken over by the lawnmower company called Haytor.
If anyone can help on identifying the valve chest, it will be much appreciated.
Looks like I should have cleared the leaf out before taking the photo, hey ho...
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #3
Thank,
I'll tak a close look.
Min is very loose there and at the left/right swing arm pivot points.
As for hydraulic controls,
Mine are the older (not joystick) type.
They are working but very worn.
I've been thinking of converting to Joystick type control.
I think the below will work.
Portable Generators, Pressure Washers, Power Tools, Welders | Northern Tool + Equipment
search for
Brand Hydraulics
Brand Hydraulics 2 Work Station Kit — Spring Center, Tandem Center with Joystick Handle | Control Valves| Northern Tool + Equipment
Brand Hydraulics 2 Work Station Kit — 3-Position Detent, Tandem Center Spooled with Joystick Handle | Control Valves| Northern Tool + Equipment
This is a gang-able control
so suggest getting an exta section an dadd to the end
in case you later want to add a thumb, post hole drill or logspitter.....
Brand Hydraulics Spring Centered Work Section, Model# 20BFT4SB | Control Valve Accessories| Northern Tool + Equipment
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #4
hi dave.
i am a new member just joined today.
aiso today bought a iseki 2160,with a loader frame on it telling me it is a l20 poly mark loader,as i was looking at so of the forums i sew a picture of your tractor with the loader on looks like the loader frame that ison mean.
i was wondering if it possible to see so close up pictures of were the loader arm fit,possible to meaure the lengh of the arms as i am going to after make these , as in your letter polymark are no longer trading so looks likeyou could help me with some informion about this loader if that is possible.
real neme tim hughes .
kind regards tim .
ps look forwould to hearing from you
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #5
Marcle,
Please explain the words valve chest.
Apparently, is a hyd valve from looking at some pictures.
It could be called a valve bank.
I even thought it could be a hyd tank.
I don't believe we use that expression over here.
Marcle,
Hi JJ
Valve chest = Valve block - assembly containing valves activated by levers or electrical coils or even pneumatic cylinders.
hi dave.
kind regards tim .
Hi Tim and welcome.
Are you in Cheshire UK as in North Wales boarders? If so I have the same machine as Dave, since your not a million miles away, you could visit to take all the dimensions you may need.
Most of the time... I run by the phrase 'if it ain't broke, don't fix it'. Having had several diggers of various sizes over the years, the multi levers are a bit old hat compared to the two levers found on the like of JCB's. Once you've been using them for a while you quickly get used to them. However compared to all the other multi lever diggers I've used, my Polymark digger had been miss plumbed on some levers as they were the opposite hand to previous machines, but simply rectified by swapping the flow and returns around so now when pulling on the levers the bucket comes towards you.
On the price of valves, they're an awful lot cheaper in the states, than over here in the UK.
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #9
Tim,
Both Macle and I have TX2140/TX2160 with Polymark Beaver Ltd.
Front End Loader (FEL) and Backhoe (rear digger).
As Marcle said He's at least on the same continent as you.
I'm glad to talk pix and measurements.
Clarification when you say "loader arm fit"
you mean were the FEL pivots on the mounts or
were the FEL subframe mount to the under chassis frame.
The whole thing is attached to the subframes with Clevis Pins.
Dave
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #10
Hi Dave
Clarification (ie) The Loader Arm is what im relating to, my tractor has got the sub frame fastened to it, but the guy I bought it from had scrapped the loader arms, bucket & rams. I just need if possible:
1) Measurments of the length of the arm?, and what is the size of the box section it is made of?.
2) Measurments of the length of the ram?
3) If you have any pictures or could take some pictures so i can work from that.. I would be most grateful.. You can email pictures and measurments to: joycehughes1956@hotmail.co.uk
Any problems please feel in contacting me on mobile: 07955613896
Kind Regards
Tim
   / Back actor/hoe on Iseki (Polymark Beaver Ltd.) - Possible maintenance issue #11
Hi
Yes I am within the Cheshire UK North Wales Border, and if it would be ok with you, I'd love to take you up on your offer and visit you and take measurments etc..
Im not sure when you would be free for me to be able to do this, so here is my number: 07955613896 in order for us to arrange this.
I look forward to hearing from you soon, and thank you very much for this opportunity, it's most appreciated.
I am not sure if this site gives out phone numbers, I will leave my wife's email address as a back up option: joycehughes1956@hotmail.co.uk.
Kind Regards
Tim Hughes.
Hi,
I'm around all weekend (or at least that's the plan today), though I may have to go to Hereford one day. Are you still interested in visiting?
UNUSED 31" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED 31" HYD...
UNUSED DSBREAK DS140A HYD BREAKER W/ BIT (A60432)
UNUSED DSBREAK...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
Here are some similar links:
