Box Scraper what size of box scraper and blade?
   / what size of box scraper and blade? #1
brian9000
Kubota M5040
I have a Kubota M5040 with FEL, the wheelbase width is supposedly 73.2". My logic says I should get a 7' box and blade in order to cover tracks, but then there is the knowledge of this group....anyone offer some advice or thoughts? I will be using it primarily for maintaining a drive.
   / what size of box scraper and blade? #2
go the 7 ft you will regret it if you dont .... and if its not for you you can sell it fast
   / what size of box scraper and blade? #3
I am using a Land Pride BB2584 for maintaining our roads and dirt working with my L5740 and like the width for road work. I am in the process of pricing something along the lines of the Land Pride HR35 Series for the added weight, strength and of course hydraulic rippers, but for road maintenance only, my present unit is fine.
This is it on my old L5030; not the same as an M Series though.View attachment 274613
   / what size of box scraper and blade? #4
You'll have no problems pulling it full of gravel. I have a jd 2320 (24HP) and I use an 84" bb on my gravel driveway with no issues, I also have a 48" bb for dirt work.
So what about the hinged rear blade on some models....pros and cons?
   / what size of box scraper and blade? #6
A hinged back blade, when unlatched, will let the front dig deeper on flat ground, or allow digging in a concave situation, like cutting down a bank. I don't know of any cons.
Bruce
   / what size of box scraper and blade? #7
if all you are using it for is driveway/road maintenance, I would contemplate getting a land plane.
I am looking at one in addition to my back box.
   / what size of box scraper and blade? #8
The only con I know is cost, it lets you dig deeper and allows you to get a good finish as it floats.
   / what size of box scraper and blade? #9
I have never seen a hinged one up close and personal, so I may be talking out of my rear end, but it seems like it could have an engineered weakness built into it to fail if it gets caught on a rock or a root.
I am sure someone will set me straight if I am incorrect.
   / what size of box scraper and blade? #10
My rear facing hinged blade always floats. It becomes rigid when I want to push some dirt in reverse.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
