anyone familiar with high ranger bucket trucks
   / anyone familiar with high ranger bucket trucks #1
spo307
Gold Member
Levittown & Long Eddy NY
kubota L4400
wrong fluid was put in aw46 hydraulic oil is too thick to pass port holes from pistol grip tubing, i was told to drain change filters and fill with ATF, this boom will be used for siding and roofing, no electrical work, sound correct
   / anyone familiar with high ranger bucket trucks #2
I could see this happening in winter but it should not be a problem in summer, the 46 is a 15 wt oil. I would contact High Ranger they were very helpful to me a few years ago with hose specs. CJ
thats what i am gonna do thanks for the reply
I contacted terex which now owns hi ranger aw 46 is a 20w oil, port holes in valves from pistol grip are small, fluid is too thick to pass fast so bucket controls are slow or dont work
   / anyone familiar with high ranger bucket trucks #5
AW32 is approximate a 10wt oil, AW46 is app a 15wt oil and AW68 is app a 20wt oil. Trans fliud is about a 7.5 wt. If you feel this will fix the problem go with whatever is cheapest. Just a FYI dextron 2/3 is the only oil Dennision recommends for their piston units, that is what I would use if you go with trans oil. Let us know the results. CJ
ATF? I have heard hi ranger oemm fluid is mil spec 5606, but at fluid change they use atf due to cost, my neighbor has a 1976 hi ranger and uses hy tran $32 for 5 gallons
   / anyone familiar with high ranger bucket trucks #8
Dextron 2 or 3 I think they are up to 4 now, it is a GM auto trans fluid. Didn't you post say they suggested it? CJ
   / anyone familiar with high ranger bucket trucks #9
Dextron XI is the latest
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
30008 (A53424)
30008 (A53424)
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
