when is is big enough to handle a 1200 lb. round bale
   / when is is big enough to handle a 1200 lb. round bale #1
1969grandpa
Belton, SC
Kubota L3540
I am going to buy a tractor and I thought I had my mind made up to buy a Bobcat 335. After talking to other people I now have some concerns about Bobcat and a tractor that small. I'm concerned that Bobcat is getting out of the compact tractor business because the Bobcat stores are dropping the tractor line and would I be able to get parts in 10-20 years from now. The other concern is a tractor that small. I have JD, NH, and Kubota dealers very local to me so I'm starting to look at them as well now. My budget it $20-25K. I can get a Kubota L3800 under $20k , L4600 for $23500 and a NH 40 for $21300. The Kubotas FEL looks like an afterthought and doesn't have NEAR the options and is more $ as compared to the Bobcat(tilt, seat, tele 3 pt, ergo, fit and finish, etc.). JD is working up some prices for me on a couple of tractors but I'm sure they will be overpriced. And of course, every dealer bashes the other brand on why theirs is better.
I want as small as I can get but still be safe with the moving bales. Would love to hear your honest opinions on the tractors you have.
   / when is is big enough to handle a 1200 lb. round bale #2
Find a Kioti dealer and checkout a DK 40SE it will fit your price range and have alot of features you will like.
   / when is is big enough to handle a 1200 lb. round bale #3
Have you looked at a grand L kubota. They are wider and heavier than a regular L series. The bobcat ct335 and kioti dk35 have been discontinued. Be sure you have some sort of ballast on the rear when you lift a bale.
   / when is is big enough to handle a 1200 lb. round bale #4
Kioti and Mahindra are affordable. Kioti makes the Bobcat line of CUT's with some minor modifications, therefore even if Bobcat were to go out of the CUT biz, I would not see a problem with parts. The Loaders (2009 models) are made by Rhino. Also check out the Mahindra 4035. Mahindra is a powerful machine with impressive specs.
Kubota didn't have a grand L on the lot but I understand that the L4600 is the same frame. I don't know the price or the differences between the two. Closest Kioti dealer is over an hour away. I'll have to give them a call this week.
   / when is is big enough to handle a 1200 lb. round bale #6
My L5740 Grand doesn't have any problems. These were supposed to be 5x6 bales might only be 5x5 though in is pic.
   / when is is big enough to handle a 1200 lb. round bale #7
The Kubota L4600 is a very nice 'basic' tractor. I personally like 'basic'. It would have no problem with 1200 lb bales. L3800 is a touch too small.
   / when is is big enough to handle a 1200 lb. round bale #8
I thought quite the opposite! But thought the same for other brands...
I guess what I ment was that the controls for the FEL are attached to the loader and some of the others are on the tractor closer to you. Just ergo for me, I guess.
   / when is is big enough to handle a 1200 lb. round bale #10
Getting the loader control that a cabbed model uses may be an option. I really like the location of the joystick on my B3030 cab. I have to believe it's much more comfortable to use.
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2010 Ford E-450 Super Duty Transport Bus (A52377)
2010 Ford E-450...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
KENWORTH ROLLBACK TOW TRUCK (A52706)
KENWORTH ROLLBACK...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
