"Top" function built into quick attach hitch
   / "Top" function built into quick attach hitch #1
bcp
Super Star Member
SW WA
Kubota BX2360
   / "Top" function built into quick attach hitch #2
It does not look easier to me. It looks a lot more complicated than the Hydraulic top link. Two pins and it's in. Then two hoses to hookup.
   / "Top" function built into quick attach hitch #3
Maybe its me but to me it looks like its meant to make the top 'hook' link adjustable.Not to actually tilk the hitch itself. But then It might be how I'm seeing it..
   / "Top" function built into quick attach hitch #4
Maybe its how i see it. But I think it looks more like its to just adjust the upper link. The hook part. but maybe it does both?
   / "Top" function built into quick attach hitch #5
One big negative that I see about this quick hitch is that you can not use it with PTO powered equipment.
   / "Top" function built into quick attach hitch #6
Maybe makes it easier to "quick hitch" to things not 100% compatible but I agree that it is fairly useless due to losing the PTO ability.
   / "Top" function built into quick attach hitch #7
The quick hitch patent drawing shows a cylinder as part of the hitch, providing the pitch function. Has anyone ever done this? It may provide an easier way for a small tractor where a regular top cylinder doesn't fit.
Bruce
View patent at:
Patent US5029650 - Adjustable quick attaching hitch coupler - Google Patents
If you can't find a hydraulic top link to fit a tractor, then you're looking in the wrong place. If I don't list it out, I will build whatever you need. Usually at no additional cost. ;)
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2005 Bomag BW266 Double Drum Roller (A54865)
2005 Bomag BW266...
2004 Freightliner FL70 Trash Truck, VIN # 1FVABTCS64HM47795 (A54865)
2004 Freightliner...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
