BX25 Aux Wiring Rear / What Size?
   / BX25 Aux Wiring Rear / What Size? #1
Artisan
Monrovia, California
Kubota BX25
I want to buy the perfect nice supple connectors to
connect to the auxilary wiring at the rear of the BX25. Does
anyone know how to call out those parts exactly?
A little harness would be great any such animal?
   / BX25 Aux Wiring Rear / What Size? #2
I recommend making a pig tail to use 2-Contact Flat Molded Connector. The bullet connectors that I used were blue, 16-14 gauge male and female terminals .157 or 4mm equivalent.
   / BX25 Aux Wiring Rear / What Size? #3
I would like to know as well.When I looked all I could find were the ones with hard plastic.They work but are not as weather tight.
I believe I found a harness, from a work light kit...
Not expensive, I ordered it, THANK YOU!
   / BX25 Aux Wiring Rear / What Size? #5
Motorcycle Electric Connectors, cheap worldwide shipping.
Terminals:
Motorcycle Electric Connector Terminals, cheap worldwide shipping.
Sheaths:
Sheaths
If you are unfamiliar with an open barrel terminal, they requires a special crimper:
DIY Relay Kit Page
When I was looking for open barrel connectors for a BMW motorcycle harness project, the company I linked to here (Eastern Beaver) had the most information available as well as the largest selection of terminals. I eventually ordered supplies from them and was happy with the product, although I ordered the crimper through Amazon.
Thank you for the input nmk61802 !
   / BX25 Aux Wiring Rear / What Size? #7
I've always called those "bullet connectors". Looks like nmk61802 has some good links.
As a general observation, I prefer the connectors and splices from the marine store to something from the hardware store. For instance, the marine style heat-shrink splices with the melting sealant are much preferred over the nasty little hard-plastic things from the hardware or auto parts store.
I only use waterproof splices on my machines.
</soapbox>
Z.
I WANT TO EXPOUND ON THIS A LITTLE FOR OTHERS IN THE FUTURE.
In the end I used radiomans recommendations. Some years ago I found
a harness that worked but now that I am a bit more electrical savvy
I realized the wire gauge in my harness was smaller than they wire
provided by Kubota. This is where things get confusing.
If you look at my picture you can clearly see "AVS-2" written on the black wire, well, the
Asians have there own wire size called "AVS" The wire back
there is a -2 size. (alas AVS-2) OK, so lets convert that to AWG sizing....
NOT SO FAST.
Here are some "assumed" facts, draw your own conclusions.
If you CLICK HERE and look at
the table, you will find all the dimensions for an AVS-2 wire. If I am reading this right
it says a -2 wire will hold 27AMPS and the conductor is 1.9mm in diameter.
Now, if you CLICK HERE you can look
for an AWG size close to 1.9mm and you get a 13GAUGE wire! Punt!
Unless I am in err, a 12GA wire is required for 20AMPs (remember the fuse is a 20A fuse)
So in the end I very carefully was able to get a 12Ga
wire inside a blue male and female terminal / .157
Thanx dsmiley... yep that is a good one for 12V
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2020 Kia Sportage SUV (A50324)
2020 Kia Sportage...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
