RTV 1100 I need more power
   / RTV 1100 I need more power #11
Think it needs a trip to the dealer. Where are you in KY. There's many good Kubota dealers in the state.
   / RTV 1100 I need more power #12
9973720wb19
His post is "RTV 1100 I need more power", so I'm assuming it is that size. All RTV1100's have cabs and air standard. And they are totally different than the RTV900 series. I've had both, RTV900 08 and then a RTV1100 09. Put a turbo on the 1100 and actually regretted doing so. More hours does make a difference and the newer 900's are much better than older versions. Turbo gave more power but at a cost to diesel consumption, now much harder on fuel. Fine adjustments to netrual fixed hard shifting problems and I boosted the pressure relief but not sure how this helped. Playing with the servo adjustment helped with the assist motor response. Plowed lots of snow, worked great, actually plowed with both machines and after getting the bugs worked out they both were great fun. One night 7:00pm -13c with wind chill of -19c and me with just a sweat shirt on, got to love the cab on the 1100 series. But the weight of about 2500 lbs makes the little 24hp engine seem a little weak for the H gear operations. Me thinks 30 hp would make this a great machine. They did lower the R gear ratio, I hear, and that would be nice as well. Other nice feature in the newer models is the sliding glass windows. Mine didn't have that feature and it was really missed.
Anyway, if he tries the muffler fix first, it may save him a trip to the dealer. And the other must is change the fluids.
Just my opinion of course.
   / RTV 1100 I need more power #13
I have a low hours 2006 rtv900 and just pulled the exhaust outlet. The screen was half plugged. I read where you don't want to cut the whole screen section off because that section is supported on the inside. I will use dremel tool to cut some of the screen out and report back.
   / RTV 1100 I need more power #14
I took only 1/3rd of the screen out(one section), and reistalled with antiseize on the bolts. I went out for a test drive and was thinking I would feel a difference on the top end. Instead, it seems like it has more grunt off the line. Like I said before, do not cut the whole screen section off because it is supported about 1/2" from the end inside the muffler. That support keeps the flange from cracking/breaking. All I needed for tools was a 5mm socket head wrench for the two 6mm socket head cap screws. RTV900 muffler 001_1.JPGRTV900 muffler 002_1.JPG
The pictures were taken after I blew all the carbon out of the screen.
   / RTV 1100 I need more power #15
On my RTV 900, IIRC the manual said to clean the screen every 50 hours or so. I just removed the whole thing. It says you need the spark arrestor for park use and since mine never leaves the farm, I just took it out and threw it in a drawer in my tool box. One less thing to maintain. It had 40 hours on it when I removed it and it was almost stopped up with soot. The screen just slipped off and I put the tail pipe back on.
   / RTV 1100 I need more power #16
Screen came off? Mine had several spot welds holding it on and the ring at the top spot welded too. They must have changed the design.
   / RTV 1100 I need more power #17
My 1100 will climb pine trees if I wanted...High range isn't good for much but level and downhill...Medium does a good job for most things...Fast it's not, but mine has more than enough grunt power....No turbo or any enhancements on mine, it's just as Kubota created it.
   / RTV 1100 I need more power #18
Hello, i live on a small watershed lake and i drive the kubota rtv1100 to and from the lake. Sometimes it just barely climbs the hill. The other day it stalled out ontop and i had to roll backwards down the hill.
It has a new fuel filter, the machine has around 100 hours since new. I really cant afford to pay the 1900 bucks for a turbo...are there any tricks or adjustments to increase its power?
I have read about spark arrestors and adjuting the HST servo will either of these help me?
This machine has always been weak, its very slow to begin to move when you step on the pedal.....almost like the brake is on but its not. In wet grass it couldnt think about spinning a tire!
Any ideas would be appreciated.
Is this 1100 a DIESEL?
   / RTV 1100 I need more power #19
That is exactly what you have to do. If you keep the pedal to the metal, the hydrostatic keeps the plates arranged for speed not power and it will stall the engine. If going up a hill and it starts to stall, just back off the pedal and it will climb right on up. My 900 climbs hills pretty good in M without backing off the throttle but will start to stall going up a steep 30 degree slope if I keep the pedal down but just letting up about half throttle keeps it moving at the same speed. Most folks that have problems with these transmissions still have the more pedal = more power mentality and that is not the case with hydrostatic. I can actually load the FEL bucket with my Kubota B 26 in High range by just easing in the pedal but if I stomped it to the floor, it has no power. The RTV works similar only the throttle works both the engine RPM and the go pedal. If yours doesnt work for you when backing off the throttle, then you need to see a dealer. I rarely put mine in H range but it is pretty weak at climbing and acceleration in that range so I mostly keep it in M. In L and M it will dig holes with all 4 tires. I use mine to pull saplings by chaining around the front or rear tow hitch ball and yanking them out. It has plenty of power
I have to ask you, how do you like your Vulcan Omni Pro 220? Been eyeing one lately.
   / RTV 1100 I need more power #20
Is your 1100 a DIESEL?????
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
Hose Reel (A55787)
Hose Reel (A55787)
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
