madmax12
Thanks for the suggestion, I do have a local Mahindra dealer and visited him this week. He showed me the 3016 (too heavy) but didn't mention the Max28XL, probably didn't have one in stock?? I was impressed by the 5 year warranty on the Mahindra. I'll check out the Max28XL before I buy.
Yes, I'm aware that a larger tractor &/or a larger tow vehicle would be "better"......but, as I stated in the original post, I AM limited by the size of the tow vehicle and I DO NOT want to buy a different tow vehicle and a new tractor.
I have been mowing the roads on my place with a little IH 234 and a 5' finishing mower.......2wd, 1200 pounds and 18hp.......I have even successfully planted small food plots with it......I could continue using it, but new fire breaks and larger food plots would be much easier to maintain with a larger tractor......so, I'm looking at tractors that have almost double the weight and horsepower and some people want to tell me that I can't do what I want to do with it???
I'm not starting a farming operation here!!! I'm talking 3-4 acres of food plots and brush hogging.......yes, I will use the FEL, but it is a luxury, not a necessity and I can certainly leave a ballast box at the property to use while there......I wouldn't leave a brush hog or disc, but I doubt anyone would steal a ballast box!!
Anyway, back to the original question.........what tractors are available in the 30 horse range, 4wd, that weighs 2250 or less??
The Max28XL has the same motor as the 3016. According to the PDFs, the Max28XL has more PTO HP than the 3016. But, the FEL and 3pt are stronger on the 3016.
In it's size, I had determined that the Max28XL had the strongest FEL, which was one of the reasons I chose it. If the FEL is less important for your needs, then so is the Max series.
Massey, for example offers a 3 range HST vs the Max 2 range (whereas the 3016 has 3 range, I think). Kubota might too, I'm not certain.
If lift capacity were primary, I would look no further than Max28. But if that's not important, than any of the brands 4wd is gonna blow your 2wd away. I leave mine in 2wd most of the time, but am really glad for the locking differential and the 4wd... it is amazing how easily a 2wd machine can get stuck.
What I did first, was open several browser windows on my desktop. Then bring up every brand of interest and go to the model of interest. Then compare window to window. Some of the brands attempt to do the comparison for you, but they "play" with that a little... like leaving Mahindra out, for example. Also, whatever dealers are near enough for your needs, go sit in all the models u are interested in. I sat on the 27hp LS and hated it. But the 33hp LS was a dream, but like you, the LS G3033 was too large for my needs. Some on the forum said the Max28 was too cramped. for me the Max28 is extremely roomy and comfortable. But the Max22/25 felt too cramped for me, even though they are also very powerful machines.
And then there is price. In my area, the LS was the cheapest, by far. But I did not pick it, for the reasons given above. Mahindra was the next best price and the strongest machine, by far.
Hope this is helpful.
