Talk Me Out of Buying a Backhoe with My New B2920
   / Talk Me Out of Buying a Backhoe with My New B2920 #1
Howard92
South Pittsburg, Tn
B2920 Kubota, GT275 Deere
Other than the cost of the backhoe, are there any other reasons I should not get a BH on the B2920 I'm buying?
I know they are some trouble to install/uninstall, but I will normally be doing that on a level concrete slab with the BH on a roll-a-round cart I will build. I will likely only be installing it a couple of times each year.
Anyone regret getting a BH on a compact Kubota?
Thanks for any help,
Howard
   / Talk Me Out of Buying a Backhoe with My New B2920 #2
A tractor without a backhoe:eek: is like...... useless?
If you want the backhoe and can afford it, get it. I have had a BX25, b2620, and am about to get a b3200. Now I sound like JOHNTHOMAS:laughing: Each has had loader and backhoe.
Sometimes they (backhoe) will sit for a period, but they are really useful. I would suggest getting the mechanical thumb. I have not used it often, but when needed it is very handy. I could live without the thumb, but life without a backhoe? It just make for a complete package.
No regrets for me about have a backhoe on compact Kubota.:dance1:
   / Talk Me Out of Buying a Backhoe with My New B2920 #3
Money and limited use was the only thing keeping me from getting one. If money was not an issue, I'd have one for sure!
   / Talk Me Out of Buying a Backhoe with My New B2920 #4
A backhoe is definitely on my "to do" list. I just haven't got that far yet.
   / Talk Me Out of Buying a Backhoe with My New B2920 #5
Howard
There are viable arguments that go both ways..BUT...personally I would use the additional $ (for the BH) and buy a bigger tractor to start with...it's not just removing the BH...it's the 3ph arms etc...
if you have the room you can find older working (dedicated BH) machines (or even rent one) for much less than a new OEM BH attachment for when you truly need and will use the BH...
If you are starting with a little (BX) tractor to start with a BH greatly raises the center of gravity and makes using the little loader even more hairy...
JMO...
   / Talk Me Out of Buying a Backhoe with My New B2920 #6
Go for it.
When I bought my little B7610 I had a Woods 70 put on it almost immediately. Probably half of my limited tractor usage has been with the backhoe. The first couple of times hitching and unhitching were a royal pain. Last time took about 15 minutes.
If you will have a need for it and the $$ are not a problem get it now.
   / Talk Me Out of Buying a Backhoe with My New B2920 #7
I say go for it even around the house the backhoe on my b26 gets used alot.
   / Talk Me Out of Buying a Backhoe with My New B2920 #8
if you have enough acres and wanting future plans to redo your land. then backhoe can pay for itself. but if you are on small amount of acerage. and not really needing to do a whole bunch. then it may be easier just renting a mini ex. when needed (save up projects and do them all at once) vs having a 3pt hitch with subframe backhoe for tractor.
stump removal, putting in gas, electrical, water, telephone, internet lines, (to house or to shed). putting in a new septic field, digging a hole for pond or swimming pool, moving heavier items in and out of truck bed or off of trailer. vs using FEL on tractor. some use backhoe with a thumb to hold up trees, to be cut, vs bending down to cut them. go with a hyd post hole digger or hyd post hammer on backhoe. to make it easier to position auger/posts. getting yourself unstuck (backhoe needs to be on) when ya drive to far into a muddy mess. have used it a few times, to make holes for plants / new trees. and also move flowers from one flower bed to other, but just taking a bucket worth of dirt and taking flowers at same time. if you need to drive back and forth on property 1/4 mile or more. i will load the backhoe bucket up with dirt and FEL up with dirt. to make less trips across the property (assuming you have a larger bucket on backhoe to make it worth while) backhoe = good counter weight for using FEL. the outriggers of backhoe, make nice "jacks" to put chains on rear tire or take chains off by lifting rear tires off ground some.
backhoes are not great for, cleaning out a lake, that has been there for a couple years or longer. due to backhoes only have 180 degree swing side to side, vs an excavator that can do a 360 degree turn to dump spoils. also excavator more easily move pads around to get in and out of a lake side.
a tracked excavator. more likely easier to dig in a small area and possibly cross a small width trench. vs a TLB (tractor loader backhoe)
if your tractor is setup for a backhoe, so you can do a 180 in seat on operate backhoe your golden. but if you have to hop off of tractor seat and then walk around tractor to get on backhoe seat. you are in for a good amount of miles walking back and forth between seats along with frustration.
backhoes when on tractor make a tractor "top heavy" and i have been known to adjust backhoe so it swings up towards the hill. so i can adjust COG (center of gravity) and reduce risk of rolling over as i go across some hills.
needing a taller garage door, and/or area within the garage. so you can attach/detach backhoe within garage. without bring the shed down onto you. *looks innocent* i tried to take house down errr the eve of the roof... *working to close to house and not paying attention that split second*
working in woods, or driving under trees. and limbs catching the backhoe, when it is in transport position. a couple trees here have had some "growing pains" as you look up into them and see a few limbs torn/twisted up.
more chance you may want to drive backwards up a hill vs driving up a hill in forward. so you do not flip backwards. due to heavy weight of backhoe on rear of tractor.
costs of buckets, and having a smaller width "trench bucket" and then a larger width bucket, for digging out holes.
costs of hyd thumb. extra hoses, valve, or mechanical thumb. a thumb turns a backhoe with bucket into like a grappel for FEL (front end loader with bucket)
   / Talk Me Out of Buying a Backhoe with My New B2920 #9
Howard
Absouletly not. I couldn't afford a new one so I luckily found a low hrs used one. Use the BH all the time.
   / Talk Me Out of Buying a Backhoe with My New B2920 #10
My brother and I had a dedicated Case back hoe; actually still do and it stays in the garage as we didn't use it enough to keep it running. If you want one, need one, can afford it (not just pay for it) have room to store it, then go for it.
We just find renting makes more sense.
2009 MULTIQUIP 25KW GENERATOR (A53843)
2009 MULTIQUIP...
Utility Trailer (A52377)
Utility Trailer...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
