Planters What are my food plot attachment options?
   / What are my food plot attachment options? #1
fishingreg
Y'all have helped me with several items in the past, I bet many of you have several different methods of making food plots. I have A L3400 Kubota and I am looking for something about 5 to 6 foot wide to make food plots. I have a tiller but my ground has a good bit of baby mesquite and cedar that are cut with a brush hog. I have seen the true one attachment food plot makers with the discs, chissels, seeder, and culti-packer. Looks like they would work good but they start at about $5000.00 and I'm only looking to do a couple acres. I want to do some clover, legumes, maybe sunflower, and sesame.
Now if some of you have the one attachment plotter and love it or hate it, please tell me about it. I am not closed to one of those, I just need to save longer.
What are your thoughts?
Thanks,
Greg
   / What are my food plot attachment options? #2
My ground is sandy loam,so cant really help that much did use a 7ft disc,now just run a fast pass over it with 74in.tiller,broadcast seed,another fast pass with tiller and roll it in(I forgot to mention I mow it as low as the shredder will go cple days before and allow all the cut grass die out)..
I would think for your ground a good first deep offset cut,maybe two...
So you basically bury your seed by another fast pass of the tiller? I had not thought about that yet?
   / What are my food plot attachment options? #4
Yeah just covering alittle tiller really not going go very deep anyways. I think your most important is getting it rolled in,I have a 12ft roller but have used my wide tires on my toyota on some smaller plots. I put out cow peas, plot mix(clover and stuff in it) and rye grass and mine have always turn out great. Timing it before or after a rain and add 100lbs of triple13 with it....
   / What are my food plot attachment options? #5
A cultipacker is a good tool to run over the area with after broadcasting seed. The cultipacker makes v-shaped ridges in the soil pressing the dirt around the seed, allowing the soil to hold moisture better and the plants to sprout quicker. We have a video here showing one in action.(click the link and scroll down)
Thanks Ted, Since I am new to this type of planting, are you saying to disk/till then seed then cultipac or maybe disk/till, cultipac, seed, cutlipac again? I would think the second as disking then seeding would put some seeds very deep.
   / What are my food plot attachment options? #7
I used my Rachet rake from TSc to break up scratch the soil 10 daysafter application of roundup, broadcast the fert and a quick rake, braodcast the seed and a another light rake to set the seed. Roll it with a lawn roller to pack. Waiting for Rain.......
   / What are my food plot attachment options? #8
I think you'd get the best results by running the cultipacker over it before and after seeding unless your seedbed is tilled pretty fine. This will break up the clods and prevent the seeds from going too deep like you said. There are many ways to get things to grow and you can approach it many ways and get similar results. Some will be better than others but you're definitely asking your questions in the best place to get quality answers from experienced people!
   / What are my food plot attachment options? #9
The latter is the preferred method, but you can do it the former method too. By packing the soil before you seed, you break up the big dirt clods and provide a firm seed bed at the same time. Then, once the seed is broadcast, you can run back over it with the cultipacker to press the seed down firmly. One point to remember, seed should only be covered no more than four times it's width. So, for clover which is very small, it should be about 1/4" deep. I realize with a cultipacker you can't adjust the depth that the seed will be covered, but I think it's a better method of covering after broadcasting seeds of different sizes to get maximum germination. You are correct, by tilling it or disc'ing it after broadcasting, you could have some seed covered up so deep it won't ever make it up out of the ground.
Thanks for all your help. Sounds like what might serve me the best and be good options are a cultipacker and a set of disks. Even for a nice heavy set it will come out at least $1,500 less than the all in one food plot maker and might serve more than the one purpose. I have a tiller but not sure I want to use it over the ground I want to break up, there are lots of little saplings and such. Seems like a disk set is in my future. Thanks again
My-D Hand 10 x 40 Auger (A50515)
My-D Hand 10 x 40...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
Stone Concrete Trowel (A47384)
Stone Concrete...
