Running Diesel additive all year long??
   / Running Diesel additive all year long?? #1
Mystro
Member
PA
BX1860
I am from the mindset of preventative maintenance in all my toys. I run Stabil Ethanol in all my gas toys (ATV,Boat,Chainsaw,etc..) I have never had a fuel system problem by doing so and the cost is nominal.
Does anyone run a Diesel additive all year long??
   / Running Diesel additive all year long?? #2
I use to use Powerservice just in winter, but this year have been adding it to every fill-up.Can't hurt and it doesn't cost that much.In my gas engines(7) I am trying a new product(to me) called Startron.I have used Stablil for years with good results.
   / Running Diesel additive all year long?? #3
Stabil Marine in all my small gas engines and PowerService in my diesels.
Both year-round.
Stabil 'cause that ferschlugginner ethanol is in the gas year-round.
I read that the low sulpher diesel needs lubricity additives that get added locally, so I'm using the PowerService as insurance that Zippy didn't forget to add the right amount of lubricity stuff at the distributor before filling the tank truck.
   / Running Diesel additive all year long?? #5
I have used Stanadyne Performance Formula Diesel Fuel Additive in all my diesels, each time I refuel I add. Never had a problem either way.
   / Running Diesel additive all year long?? #6
Stanadyne Performance Formula Diesel Fuel Additive Year round
   / Running Diesel additive all year long?? #7
I think you need to put a shield around that tractor so the shine doesn't damage someone's retina. Did you really use tire black on the plastic gage wheels?
Keeps em shiny and the dirt/snow slides off. Its in its parade uniform.:D
   / Running Diesel additive all year long?? #9
I use the additives all year not rich enough to have two seperate tanks :D What is it gonna hurt? If it would hurt something then why use it at all?
   / Running Diesel additive all year long?? #10
Mystro, that's a fine looking tractor.
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2022 Horizon Trailer (A55973)
2022 Horizon...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
