Seafoam
   / Seafoam #313
carbon removal in ring lands and on top of piston would be my guess...
   / Seafoam #315
as soon as we piss SW off again, it will climb to over 100
I think he's like bruce banner / the hulk in the avengers movie. he summed it up perfectly.
" See.. my secret is.. I'm ALWAYS angry ".....
   / Seafoam #316
I just put some seafoam in my Ryobi 2 cycle powerhead because it was getting tough starting. Fired up and smoothed right out. Good stuff. I like it. Dumb me...
   / Seafoam #319
Why would you want to spray it????
It is an excellent upper engine cleaner and is one of the ways the directions on the can even mention to use it and its great penetrating oil. Both obviously require it to be sprayed either into the intake or on rusty bolts etc. That's 2 ways it can be used as a spray I can think of.
Like Clemson I also have a 1 qt pressurized metal spray can I use to spray the liquid SeaFoam etc (solvent whatever) its just not as handy under some instances as the aerosol can where I need to bend the little plastic tube to get into somewhere tight and the aerosol cans can be sprayed upside down that is my pre-requisite for penetrating spray oil. fwtw
   / Seafoam #320
To get it either in air intakes on cars without letting Manifold vacume suck it in or i spray it into the spark plug holes on my out board and let it soak after hand rotating the engine.
200387 (A51247)
200387 (A51247)
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A54757)
UNUSED RAYTREE...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A53421)
2018 Toro Z-Master...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
