JD 2440 hydraulic squeal
/ JD 2440 hydraulic squeal #1
cbailey1956
Bedford, VA
Allis Chalmers B, Komatsu D31, Case 585
Hello, neighbors 2440 (yes really my neighbors) hydraulics are squealing. When using the rear remotes to operate the loader and or operating the 3pt lift the noise goes away. As soon as hyd pressure is not needed the noise resumes. Steering circuit has no effect on noise (works great). He brought it over after talking to me and saying he had changed a hose and the loader no longer worked. I would say it had a few hours running before he brought it to me. I traced the loader problems to incorrect routing of lines to the two rear remotes. Rerouted and reinstalled lines. Now the loader works fine and has good pressure/pwr. The squeal persists unless operating a circuit. It sounds like a relief valve to me but I dont know where they could be located. I have looked over the tractor and it appears to be a closed circuit radial style pump up front. I am assuming there is a charge pump somewhere internal and hard to get to. There are two large lines running from the rear to the front pump / cooler. 1 pressure line running rear that has a T feeding the steering and going through a small valve assembly prior to suppling the rear remote valve assembly. I plan to drain the fluid and pull what looks like a filter assembly from the bottom. Is there a screen somewhere and are there any valves I can inspect without major disassembly. Oh the tractor has the hyd hi/low selector on the dash. It shifts fine and no noise while changing lever. The pressure line is vibrating/chattering while in operation unless fluid is used to operate remotes / lift. Any hints/advice?
Craig
/ JD 2440 hydraulic squeal #2
A good place to start is to change the filter and drain the transmission fluid and check the sump screen. Sump screen is located on the right side of the transmission, just behind the filter housing. There is a large plug there that takes a 1/2" drive breaker bar to loosen it. Tap on the plug a couple of times with a hammer to make it easier to come loose. The screen is about 10 or 12 inches long. If there is any debris on the screen, it is important to identify what it is. If it is brake material(tractor has wet brakes) brakes need to be repaired to prevent further contamination and damage to the system. If the noise persists after filter change and screen cleaning, you could have a high pressure internal leak. Can you tell where the squealing is coming from? Do any of the hydraulic components get warm/hot when running? Will the three point stay up with engine off? Does the loader have an independent valve or is it operated from the remotes? What model is the loader? Some of these tractors had a "buzzing" noise from the shift lever area that is somewhat normal. It is irritating, but causes no problems. It is caused by the pressure regulating valve for the Hi-Lo vibrating in the shift cover housing. You probably should also check main hydraulic pressure(2300 psi) and transmission pump pressure (around 140psi). Also, you are correct, the transmission pump acts as the charge pump for the main pump. It is located in the rear of the clutch housing.
Thanks for the info. Tomorrow if time permits I will drain and check filter and screen. The loader has no info on it, it is operated with hoses from the rear remotes. I will check main PSI at rear remotes. Where is the transmission psi port? I will raise the 3pt and see if it holds also. Thank you
/ JD 2440 hydraulic squeal #4
With 3pt raised,engine running look inside hyd filler hole at the rear of tractor for spraying oil. This is a very common hyd leak problem on JD utility tractors. The stroke control valve(parts keys 42,43&44) that controls pressure is in the head of the frt pump. Stand-by should be in the 2250-2350 psi range. The valve on RH side back by hyd filter is the pressure control valve that gives steering priority hyd pressure. If tractor has ind pto(control lever between gearshift levers) there's a trans test port under sheet metal cover the gearshift lever protrude through.
/ JD 2440 hydraulic squeal #5
In the drawing Jim posted there is also a filter screen (#17) that I would check too.
/ JD 2440 hydraulic squeal #6
Steve
You're correct and thanks. That filter gets forgotten about.
Today I drained the oil, it was clean and no burn smell. Main filter was clean, no debris visible. Screen was about half covered with bits of rubber , only one metal thread like debris. After reading the above info I wanted to pull the filter in the front pump but it was so covered I had to stop and pressure wash which led to fixing the psi washer first. Got it cleaned and will check that filter tomorrow. I wanted to ask about the steering priority flow valve. Can it be taken apart and inspected after removal. I would do front valve/ filter and priority flow valve before reinstalling filters and fluid. Then check pressure and 3pt leak as per above. And yes the tractor does have independent PTO. Thanks for the help so far.
/ JD 2440 hydraulic squeal #8
Yes the pressure control valve can come apart. You will want to get orings #11, 12, 13, 15, and 20 to reassemble. RWP3653________UN01JAN94.gif
Took the filter (#17 above) out and it was clean, took the stroke control valve apart and inspected, nothing noticed. Disassembled and inspected steering priority valve, looked good. Checked pressure at rear remote (2700). Took off transmission cover and want to check charge pump psi but found many test ports. 3 on shift plate cover, 3 on lift cover housing, 2 on right side of lift cover forward of the 3 pt lever and 1 on the front edge under the trans cover. all appear to be #3 SAE and I am looking for a test fitting to check pressure. I also looked through the fill port and saw no fluid spraying while the lift in up and also moving. The lift stays in the raised position and holds in respect to the lever position.
I am leaning toward the front pump. While running the pressure line vibrates and the noise appears strongest while listening up front. The loader also appears to be "stuttering" while operating at times. Need to get the charge psi checked but any more suggestions. The noise is more of a rattling rather than whining sound.
/ JD 2440 hydraulic squeal #10
First you need to lower stand-by pressure to 2350-2400 psi maximum. Are the hyd line clamps(parts keys #18 & 21) in place and snug?? I've seen tractors with these missing and lines rattle/vibrate. What type valve controls loader???
/ JD 2440 hydraulic squeal #11
RP136__________UN01JAN94.gifI agree, lower that pressure down to 2350 and check the clamps on the lines. The trans pump pressure can be checked at plug on the right side of the shift cover. That is the port for the pressure for the Hi-Lo. The loader stuttering at times might be due to running the loader off of the rear remotes. From the factory, the rear remotes return their oil to sump, through a short 3" hose between the valve and the three point housing. If that short hose is there, you should change that routing so it returns to the filter cover. The transmission pump does not have enough capacity to supply enough oil to the main pump for steady raising and lowering loader cylinders. If return oil is routed to filter cover, it is sent directly back to main pump to assist the trans pump. Is there a hose attached to the cover? Do you have a ported filter cover? If the cover has no port for attaching hose, a new cover is required. You can then remove the short hose with clamps and put plugs in place of hose nipples. Then on the outside of the remote valve housing directly opposite of original hose is another plug. Run a new hose from valve to ported filter cover. Illustration shows the conversion kit. Part number is listed as AR71945.
/ JD 2440 hydraulic squeal #12
The tubes supplying oil to the hyd pto have been known to leaking robbing supply oil from trans pump to main pump. For diagnostics remove and cap power steering line(parts key #10) and operate hyd's and see if noise is still present.
/ JD 2440 hydraulic squeal #13
Part of the problem is somebody who should be slapped. Went and supplied the loader hydraulics from the scv. Install a T in the line prior to the rockshaft and scv valves to supply the loader controls.
DO NOT return loader or hydraulic motor oil direct to the trans sump. The transmission pump is much lower gpm than the front pump . Return loader oil via a ported filter cover.
/ JD 2440 hydraulic squeal #14
buickanddeere
You should have gone over to Welland,Ontario and slapped the JD engineers that put the hyd SCV control kits as an option in the loader ordering codes for JD utility tractors. Obviously they didn't agree with you or there wouldn't have been the loader SCV control option from JD's factory. FYI the factory codes didn't included "ported filter covers" for SCV controlled loaders. I know because I sold the loaders when they were "NEW". I did not state ported filter covers weren't better but in limited loader operation SCV control of loader is very adequate. Adding a tee, 2 spool valve and ported filter cover is going to cost in excess of $500
/ JD 2440 hydraulic squeal #15
buickanddeere
From personal experience, the shudder, slow speeds and hydraulic noise all went away when our 2020 was converted from SCV to a T and ported filter cover.
The 2nd factory SCV was not a cheap option. And leaves the tractor without a SCV to use with other equipment.
/ JD 2440 hydraulic squeal #16
Maybe that was correct on your tractor but that doesn't discount that JD ENGINEERS didn't think the SCV controlled loader was as terrible as you make it out to be. Some people that bought tractors with loaders operated from SCV may not even own drawn hyd controlled implements so they could care less if the scv's are tied up operating loader.
/ JD 2440 hydraulic squeal #17
Seems a strange option to choose an extra scv, not have an scv to use and have slower/noisier hydraulics.
Instead of a T, ported cover and a joystick for similar $ . And have a much better performing loader.
/ JD 2440 hydraulic squeal #18
My point was if someone has a JD utility tractor that has hyd issues with the loader operating from scv's changing it to a tee with an ind valve & ported filter cover is not going to necessarily be a magic cure to the hyd issues for the extra $$$$$$$$$$$$ spent. Just because that fixed your tractor doesn't mean it's a magic cure-all.
Removed and capped steering line, noise remained. Installed pressure gauge and charge pump pressure is 140 at idle, 160 above idle. The valve assembly has the 3 inch line between the valve and lift cover. I did lower the pressure down to 2350 PSI at the rear remote and the noise reduced significiantly but not completely. I was wondering about the fluid flow through the 2 large lines. I missed originally a crimped line which could be limiting flow from the charge pump to the front pump. It is not completely crimped close but enough to reduce flow. It is the lowest line on the rear housing that goes forward. My concern is the noise goes away when rear remotes operated and or 3pt raised. Returns when no fluid flow is needed. Steering circuit has no influence one way or another on the noise. The owner will be by tomorrow so I can discuss where we are so far. Thanks
2020 DRAGON ESP...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
1991 International 4900 Box Truck (A55315)
1991 International...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
FERGUSON 2 ROW CULTIVATOR (A60430)
FERGUSON 2 ROW...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
