Rebar chair spacing.
   / Rebar chair spacing. #1
wedge40
Getting stuff together for cement pour. 40'x56', 5" thick, 3/8" rebar on 1' spacing. How far apart can I space the chairs.
Wedge
   / Rebar chair spacing. #2
With 3/8" bar and the activity of them walking all over the bar as they pour, I'd say you need the chairs at about 2' max along the bar. If you want to be sure there will be no significant bending during the pour, you'll have to go closer.
If you have a grid with the bar on 1' centers, running both ways, put the chairs under just the lower bars and offset on each one, or staggered. I'd try it with the 2' OC layout, staggered, and step on it to see if you are satisfied.
Thanks John, that's exactly what I was looking for. I was afraid I was going to get some nebulous answer. I can purchase for 18" along one way and should have more then enough.
Wedge
   / Rebar chair spacing. #4
Ya dont use too many or the concrete flowing into the slab will just knock them out of position and float them away cause there is not enough weight on them to hold them in place.
   / Rebar chair spacing. #5
Have you bought the rebar yet? Two years ago when I built the slab for my garage it was cheaper to buy 1/2" than 3/8". I'm not sure if that's still the case now.
   / Rebar chair spacing. #7
My contractor tied the chair with that very type of handle and ties. They worked decent however he put them on 2' OC and in some areas near the intersection points I noticed that the weight of the rebar was crushing the chairs. I went back in and had to add some more chairs in strategic spaces.
My guy was trying to skimp in places though. He didnt want to cut shorter pieces of rebar so he took several bent t-post that i had laying nearby and threw them in instead. Of course i didnt know about this until my wife told me AFTER the pour.
   / Rebar chair spacing. #8
Don't you just love contractors that borrow your tools and supplies! I had a basement repair job and they borrowed my wheelbarrow, 1/2" Milwaukee 18v drill, and several metal chairs.
You should have done another pour and put the contractor in.
No haven't bought the rebar yet. 3/8" can only be found at Menards and IT IS cheaper then 1/2" I'm going order the pex and manifolds today. Hope to have the company I order from do a basic layout. Got a couple of places I need to work around. I want to have everything set and ready for a 2 post lift in the future.
Wedge.
   / Rebar chair spacing. #10
wedge,
Here are a few pix that might help you with your radiant layout. it's just common sense. I've found it counter productive when a PEX or manifold supplier tries to give or sell you a layout. A few basic rules to follow and a bit of thought will get you what you want. It's much better for you to design it, and understand it, than it is for an unexperienced guy to do a roll out design from his office, for you.
Figure out the number of loops you want and don't let the supplier tell you how many. In the pictures you'll see I ran 3/4" PEX on 12" centers over most of the area. You might want 1/2" tubing which is more common, I don't know.
Also, I used concrete dobies under my bar. They tie to the bar with tie wire that comes sticking out of them.
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
1985 Chevy C8500 Altec D800 Digger Derrick Truck (A50323)
1985 Chevy C8500...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
