1970 Ford 3000 gas unit...trans/hydraulic info needed....
   / 1970 Ford 3000 gas unit...trans/hydraulic info needed.... #1
BobG_in_VA
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
I've got a good friend that has a '70 3000 gas unit...he's redoing the hydraulic pump. Wants to change all the fluids. He ask me how much fluid to put in..I don't think he has the manual..Soundguy/other Ford folks...how much trans/hyd goes in the trans and how much in the diff? Appreciate it!! BobG in VA
   / 1970 Ford 3000 gas unit...trans/hydraulic info needed.... #2
off hand.. I don't recall.. but there are level check plugs.
trans is one sump.. hyds and diffy are another.. diffy level check is a pip plug on the back side of the left axle trumpet.. trans is a plug on the right side by the running board
   / 1970 Ford 3000 gas unit...trans/hydraulic info needed.... #3
both plugs should be on the right side above the running board the one in trans and one in the diff right below the flow control valve and the i believe it should take around 7 to 8 gallons to fill both compartments
   / 1970 Ford 3000 gas unit...trans/hydraulic info needed.... #4
(edited)
yep.. you're right. more I think about it.
my lat 68 3000 square axle don't have a plug on the left axle trum[et like the 00/01 do.. .. it does have plug on the right side center housing aft of the running board.
the 4000/4600 have the plug on the pump round plate or near it.. and the 5000 will have that plug back there in back.
too new for me sometimes.. :) i like the prior models better.. :)
   / 1970 Ford 3000 gas unit...trans/hydraulic info needed.... #5
(edited)
i dont blame you about liking the prior models better they seem to me atleast simpler to work on
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
2002 LULL 644B-42 TELESCOPIC FORKLIFT (A51246)
2002 LULL 644B-42...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
