2012 NH Boomer 30 HST or Kioti CK30 HST? Value?
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value?
Dealer: "Yes, the New Holland Boomer 30 Tractor is equipped with 3 point hitch telescoping lower links and SSQA.
The Boomer 35 is a big jump in price from the Boomer 30, something like $2750 additional. The Kioti CK35 HST is $895 additional to the cost of the CK30 HST."
There you have it. Boomer 35, just not worth it to me.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #142
Does the Boomer 35 jump up a frame size?
Same frame, dimensions, and ironically, identical weight. But goes from 28 HP to 38HP. Must be same engine, larger cylinders.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #144
After this thread you are more educated than a salesman.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #146
Or turbo.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #147
Well if you're looking at the Boomer 35, might as well look at the Mahindra 3616 ? :) lololol ! Welcome to tractor shopping ! BTW, love my Mahindra, and, you'll eventually get a free Mahindra owner hat in the mail ! Lololol ! Whatever you wind up with, enjoy.
Rich
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #148
Or turbo.
Same weight means it might be an anti-gravity turbo. :D
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #149
According to tractordata.com the boomer 30 has a 1.5L engine and the boomer 35 has a 1.8L engine. The boomer 30 is 22 pto and the boomer 35 is 30 pto.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #150
All the new NH (LS based) compact tractors' engines are natural-aspirated. The Boomer 30 is using a Mitsubishi S4L engine while the Boomer is using a Mitsubishi S4L2 engine. The S4L2 has greater displacement than the S4L. The NH specs are screwed up on their website as the website states that the Boomer 35 is ~28" longer than the Boomer 30, yet the the NH paper brochure states they are the same length at 119". The same goes for the weight were the website states they are both 2913lbs, yet the paper brochure states the Boomer 30 is 3121lbs and the Boomer 35 is 3200lbs. I wish NH's marketing group would get their tractor specs consistent.
In addition, The Boomer 30 and 35 states the 3PH lift capacity is 1807lbs at the ball ends, so that means it has a lift capacity of about 1535lbs at 24" aft of the hitch (the NH Boomer 2035 3PH lift capacity was ~1925lbs at the ball ends and 1635lbs 24" out). There is about 15% to 20% difference between the ball ends and 24" aft lift capacities on a 3PH for this size tractor. It does not surprise me that the NH Boomer 35 is $2,750.00 more. It seems that anytime you move up a model size, NH will charge about $2,000.00 to $2,500.00 more, however, that dealer seems to be a little high with that price. JD and many other manufactures do the same thing, I guess except for Kioti.
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
