Seafoam
   / Seafoam #341
i heard a cobra bit CN one time.. after 2 days of agony, the snake finally died.. ;)
   / Seafoam #343
lilranch2001 said:
Soundguy won page 35 contest
Only because Chuck let him.
   / Seafoam #346
Okay, so I have heard about this seafoam stuff on my automotive forums that i frequent, but have never tried it.
This thread however, inspired me to give it a go.
I had a stihl weedwacker that had sat and wouldnt start without starting fluid, and once started, would run, but you had to be careful or it would die....other words it ran pretty rough.
I had a stihl chainsaw that did the same thing a couple years back and I ended up taking it into the dealer and paying 80 bucks for them to rebuild the carb.
So, I dumped a couple of ounces into the tank and turned it over a few times and then let it sit.
After about an hour I used starting fluid to get it started.
It ran rough as usual for about 3 min then it started to smooth out. I then began to idle, which it hadnt done in quite a while.
I set it down and let it idle for 5 min then picked it up and revved it.
I immediately noticed that it ran smoother...no question about it. It sounds great now. Like a new engine.
   / Seafoam #347
Sounds like nuther convert
:thumbsup:
   / Seafoam #348
Yes, the SeaFoam Saber is most magnificent!
   / Seafoam #349
It ain't nuting but snake oil.
It gets in there and snakes through those little holes and tight places so it is ain't really majic at all. :D
   / Seafoam #350
Have you noticed the degree of articulation in a snakes spine. SeaFoam enables that; remarkable.
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
