crazyal
Super Member
Good read from Ford 6.0, 6.4 and 7.3 Oil Bypass Systems and Billet Aluminum Filter Caps
So it reads like if I put a bypass system into my F350 I could get by changing oil 15K or more.
It's not that simple. There's three properties that need to be checked, contaminates (which they are talking about can be filtered out), additives used to modify the way the oil acts when cold (or in the case of synthetic warm), and detergents used to keep the engine clean. If you filter the oil better then the need for detergents to keep the engine clean drops. However unless your engine is always at operating temperature, say a semi that the engine is always running or a locomotive that also rarely shut off you will need those additives.
The vast amount of damage done to an engine is when the oil is not at it's operating temperature. Usually around 200F. In the old days we had just plain old 30 weight oil (along with other weights). But what happens is 30 weight oil at room temperature did a very poor job lubricating engines. So along came 5w30 (and others) oil. Oil that would act like 5w weight when cold but once at operating temp it was 30 weight. To make it act like 5 weight additives were put into the oil. Over time these additives break down and the oil will become plain old 30 weight oil. Older engines were designed with looser tolerances to work with straight 30 weight oil while modern engines are not designed to run on straight 30 weight oil.
Synthetic acts differently. Conventional 5w30 oil is 30 weight oil with additives in it to act like 5 weight when at room temp. Synthetics are 5 weight oil with additives to act like 30 weight when at operating temps. So when the additives break down it becomes straight 5 weight. Since most wear happens when cold having too thin of oil at operating temps is not as much of a problem. That's why it can go longer between changes.
