Is it a pain to raise trailer GVW?
   / Is it a pain to raise trailer GVW? #1
wny770
Gold Member
WNY
Lots of old iron
I want to raise my trailer registration from 10,000 to 12,000. I live in NY. Anyone do this? how much of a pain is this to do. My trailer is well capable of 6 ton. Weighs 3800 lbs dry, and with my bigger tractor I'm about 10, 600 and don't want a fine in this most generous state.....
   / Is it a pain to raise trailer GVW? #2
How do you propose on doing it? Does have a home made registration?
   / Is it a pain to raise trailer GVW? #3
If it is a factory buillt, purchased trailer it can only be registered to max rating they put on the build sheet that was used to generate the title.
   / Is it a pain to raise trailer GVW? #4
you would have to register it as a homemade trailer. you will need to prove the tires and axles are up the the task of upping the weight. Then you will need to tow trailer to nearest certified scales and get a printed sheet of weight. Then and only then you can go into dmv and jump through the hoops with paperwork and register it with a new VIN .
   / Is it a pain to raise trailer GVW? #5
Depends totally on whether it is registered for the titled weight or not. if it is, then all the above is true. If not, it can be re-registered for the titled GVW without much hassle.
   / Is it a pain to raise trailer GVW? #6
You can have a 10k gvw trailer and register it for anything under that.
   / Is it a pain to raise trailer GVW? #7
Around here many people that have a trailer with a 20k rating for example will register it as 10k rating so they don't need a yearly safety inspection. They must keep in mind that they can't legally tow the big weight. That can be changed pretty easily.
   / Is it a pain to raise trailer GVW? #8
I know a guy that had a 7k or 10k trailer registered for 4k, the registration is cheaper. He is afraid to haul anything heavy on it. In Virginia anything over 3k must have brakes and be inspected yearly. I hate yearly inspections, they are a waste of time.
   / Is it a pain to raise trailer GVW? #9
once you register over 10000 and if your combination weight is over 26000 you will need class A CDL, also your truck will need dot #'s on it at all times when towing a 10000 GVW magnets are not allowed.
   / Is it a pain to raise trailer GVW? #10
Around here the easiest way is to lose the Title and have a new one issued as a home built trailer.
You may not be overweight though. Take it to a scale with your heaviest item on it and weigh it out. All that matters is what is on the axles for both the trailer and the truck, that you dont exceed your trucks GCVWR, and its GVWR.
Being only 600# over by your guesstimate, you may not be when you consider the weight on the truck via the hitch. A 10,000# load should have 10% of that on the ball so about 1,000# of tongue weight which will now be on the truck.
Chris
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
