Removal of Bobcat 743 engine
   / Removal of Bobcat 743 engine #1
bratvold
Corcoran,mn
Bobcat 743
I have a hydraulic leak that I've been told is servicable only by taking out the engine and replacing some oil lines. I've swapped auto engines and transmissions before but never on a diesel Bobcat. Can anyone point me to any reference material that might be out there or share any do's and don't you may have yourself learned when pulling a Bobcat engine? Thanks in advance. Greg.
   / Removal of Bobcat 743 engine #2
I am in the same boat as you. Getting ready to pull my engne to do the same. If you provide your e-mail, I will try and send you an electronic copy of the shop manual.
Thanks so much! My email is bratvold@comcast.net
I've read on other sites that the engine removal is pretty simple. I might start to tear into it by middle of next week. Why are you taking your engine out?
Thanks again. Greg Bratvold. (Minneapolis,MN)
   / Removal of Bobcat 743 engine #4
A bad leak. I thought it was the hose which has the nut between the bottom of the loader pump bay and what looks like a control valve. No way to get to it without pulling the motor and pump. Trying to send the file. It is a little too large. I will figure a way though.
A bad leak. I thought it was the hose which has the nut between the bottom of the loader pump bayand what looks like a control valve. No way to get to it without pulling the moter and pump. Trying to send the file. It is a little too large. I will figure a way though.
Per sending a large attachment...............
Send me just a quick note without the attachment so at least I have your direct email.
My family and I have been using 'dropbox' for sharing large video files between family members. It's free and worth a look. >Greg.
   / Removal of Bobcat 743 engine #6
You should have it Greg. Thanks for the dropbox tip. Worked great!
   / Removal of Bobcat 743 engine #7
Sorry for the typos. I corrected them in my original post.
2018 PETERBILT 579 DAY CAB (A57880)
2018 PETERBILT 579...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Deere 350G LC (A53317)
