Removal of Bobcat 743 engine
   / Removal of Bobcat 743 engine #1
bratvold
Corcoran,mn
Bobcat 743
I have a hydraulic leak that I've been told is servicable only by taking out the engine and replacing some oil lines. I've swapped auto engines and transmissions before but never on a diesel Bobcat. Can anyone point me to any reference material that might be out there or share any do's and don't you may have yourself learned when pulling a Bobcat engine? Thanks in advance. Greg.
   / Removal of Bobcat 743 engine #2
I am in the same boat as you. Getting ready to pull my engne to do the same. If you provide your e-mail, I will try and send you an electronic copy of the shop manual.
Thanks so much! My email is bratvold@comcast.net
I've read on other sites that the engine removal is pretty simple. I might start to tear into it by middle of next week. Why are you taking your engine out?
Thanks again. Greg Bratvold. (Minneapolis,MN)
   / Removal of Bobcat 743 engine #4
A bad leak. I thought it was the hose which has the nut between the bottom of the loader pump bay and what looks like a control valve. No way to get to it without pulling the motor and pump. Trying to send the file. It is a little too large. I will figure a way though.
A bad leak. I thought it was the hose which has the nut between the bottom of the loader pump bayand what looks like a control valve. No way to get to it without pulling the moter and pump. Trying to send the file. It is a little too large. I will figure a way though.
Per sending a large attachment...............
Send me just a quick note without the attachment so at least I have your direct email.
My family and I have been using 'dropbox' for sharing large video files between family members. It's free and worth a look. >Greg.
   / Removal of Bobcat 743 engine #6
You should have it Greg. Thanks for the dropbox tip. Worked great!
   / Removal of Bobcat 743 engine #7
Sorry for the typos. I corrected them in my original post.
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2016 Morbark Chipper (A55787)
2016 Morbark...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
