Backhoe Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard)
   / Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard)
Another non-orthodox solution in repairing metric flat face seal fittings
Since the availability outside of China seems non-exixtent, those chinese metric fittings are becoming hard currency here, you can carefully cut open the ferrule of the broken hose and reuse the old fittings with a new ferrule and new hose.
IMPORTANT NOTE:
I got a strong recommendation not to reuse the old fittings, that's a no-no especially on hoses with high pressure, that can cause personal injuries.
Re: Metric Thread O-ring Flat Seal Hydraulic Hose Fittings (Chinese standard)
We had to replace the boom cylinder of our LW-7 (2010) backhoe. Unfortunately the hydraulic fittings here were larger (M18x1.5mm) than on the original (now with a broken piston) cylinder (M16x1.5mm).
Either we had to custom make two new hoses, or to custom make two adapters. We opted for the latter, since we all know the rare/100% non-existing availability of these Chinese Standard press fittings outside of China.
P.S.
ORFS are never Metric, so remember to name these Chinese fittings correctly!:
"Metric Thread O-ring Flat Seal Hydraulic Hose Fittings"
   / Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard) #13
I know we've discussed this before, but ORFS is a generic term that applies to this type of fitting, regardless of any proprietary name.
I digress.
   / Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard) #14
I digress.
I think that a o-ring face seal has protection against the o-ring becoming entrained in the fluid flow, which is a hazard of the flat seal.
Here is a page where they are offering metric o-ring face seal fittings, but if I am seeing it clearly, they have protection against o-ring entrainment.
   / Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard) #15
"Here is a page where they are offering metric o-ring face seal fittings, but if I am seeing it clearly, they have protection against o-ring entrainment."
Where??? Not nice to tease me like that! :confused3:
   / Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard) #16
   / Metric Thread O-ring Flat Seat Hydraulic Hose Fittings (Chinese standard) #18
That link doesn't work, Fishin99.
2023 JOHN DEERE 8R310 LOT IDENTIFIER 188 (A53084)
2023 JOHN DEERE...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
Charlotte County (A50323)
Charlotte County...
JOHN DEERE WHP48A LOT IDENTIFIER 98 (A53084)
JOHN DEERE WHP48A...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
