I Beam for structural support
   / I Beam for structural support #11
Plus the steel yard said it could
How would they know, unless they sent an engineer over, or you gave them a pdf of your structurals? At which point, who are we to second guess a PE
From a wise man on ContractorTalk
Structural Advice - Framing - Contractor Talk
I have been a framing contractor for 25 years and I have not yet seen it all. When I think I do, I drive by a jobsite where the framing contractor has neglected to read the truss specs carefully for piggy back trusses and are lacking proper bracing. It is my duty as someone who knows better to stop in and remind them to carefully read the truss specs on bracing and how their ignorance at erecting the system will fail and possibly kill someone.
I've seen many threads here asking for structural advice and personally, it's not any of my business to give out structural advice. We owe it to the people who request this here to steer them in the right direction and that direction is straight to an engineer, architect, or lumber yard who has a qualified, in-house engineer who will have a stamp that can and will stamp a set of plans for you.
I am a framer, not a structural engineer. I don't design structures. If you are a responsible structural engineer, you already realize that unless you are personally standing right there looking at the particular situation, you would know better than to respond with "you need this size" because YOU DON'T KNOW THE WHOLE SITUATION and will be liable for structural advice!
When it comes to framing, I am responsible for putting the structural members in the place where the architect, engineer, or designer tells me to put them. Period. That is my liability. It is also my responsibility if I put something in that is sadly undersized. As a framing contractor, I must possess general knowledge of what is needed structurally for the building. This is not a business trade that you just pick up a hammer and say "I'm now going to frame homes for a living" If something is undersized, a call to the structural designer is needed.
Floor joists? That is a gray area. You can easily find span charts in the code book and online. However, youstill need to know what your local codes are for your situation. Same with your wood species. Same with the modulus of elasticity. Same with the deflection.
To someone who responds to a question, are you going to take full responsibility for someone's floor being bouncy? Are you going to place your signature on a piece of paper saying that it is right for the situation and if something fails or isn't satisfactory, then you will bear full responsibility?
Rafters? No. Because you will have no idea what the snow loads are, or what the roof is really carrying, or what the local code says you need for live and dead loads or what is REALLY going on at the specific site and situation. These loads differ from community to community. Where I live, oceanside is lower than inland. Mountains, different even still. Ours is 40#, the next town over is 60#
Beams? Not a chance. There is no possible way for anyone to be able to tell someone else online what their exact conditions are.
Please stop giving advice on what you think "should be good enough". If you are not doing the calcs for the OP and giving them your state issued stamp of approval on a set of plans, stop giving this advice before you kill someone. This is not a game. This is structural design.
   / I Beam for structural support #12
That sums it up very well. If you don't know the load, you don't know the material. And a parts guy behind the counter is not a structural engineer.
This is not rocket science, so look it up and adjust your spans, if necessary, to make it practical for you. Never build your building, and risk your life with hoists, based on online speculation from others who don't know either, and don't know your conditions.
I understand he isnt a structural engineer, he made a minimum recommendation based off what I told him... the purpose of the beam is to open the barn up to move equiptment around easier without poles to get in the way.... so the span has to be 30' long. I posted this question because I thought someone might have already experienced a similar situation. I am merely looking for suggestions.... personally if you dont seek input from others you may overlook something very important... while I dont plan on installing the beam based solely off other peoples suggestions.. it does help you form a consensus of the "norm". Thanks for your input.
   / I Beam for structural support #14
Shibaura:
To be safe, I suggest you consult a structural engineer. I'm no structural engineer; but that beam the steel yard suggested is way too light for the double duty you want it to do.
   / I Beam for structural support #15
Two thoughts come to mind, but you may have already thought of them.
Separate the functions-use a truss for the roof and a beam or a wheeled gantry crane for the hoist.
Don't put lots of "engineering" work into the beam and neglect the posts or support system for the beam.
mjncad: thanks for the advice, I tend to agree..... bcp: your thoughts have crossed my mind but would like to kill two birds with one stone if its practical enough... the hoist was an after thought to installing a beam its not a necessity... to me the beam seems like a simpler solution than adding truss but I could be wrong... Is it safe to assume a truss system would be bit more cost effective than an Ibeam?
   / I Beam for structural support #17
Just for the roof support, I would expect the truss to be less expensive than the beam. For a combined function, I don't know.
Bruce
bcp... I think so too...I 'll get a couple professional opinions on what size beam I will need and then decide on which support system to go with. Most likely cost will be the deciding factor.:D
   / I Beam for structural support #19
If you knew your loads you'd have a fighting chance to pick out a beam. There are books with charts, and charts all over the Internet. But you need an engineer in the worst way.
Here is a wide flange chart I scanned, for point loads divide the capacities in half. I'm only giving this to you so you can see there are charts everywhere, but you need an engineer! ;)
   / I Beam for structural support #20
If you are handy with math, and do your homework, beamboy is a great tool for beam sizing.
As others have said, dont take the sales-guys advise. He dont knwo your loads. And I nor anyone else here does either. All we can do is guess and speculate, so I will give my best guess.
For starters, we dont know the roof load. But since it is a rafter and ridge beam, and you mention two vertical posts supporting the ridge beam, I will make an educated guess here....
Since the end and side walls also share the load of the room, and I will assume the vertical members are evenly spaced @ 10', and the building being 30' wide, Each post is supporting a roof area of roughly 10' x 15'...or 150 sq ft. Now I dont know what your roof is designed for so just guessing that live and dead loads will add up to ~50psf. So each vertical member should be capable of holding 7500lbs.
So now we need to size a beam, 30' clear span, able to hold two 7500lb loads @ 10' and 20', AND for a trolley/hoist. Lets just size that for 1-ton. Loading will look something like this beam.PNG
And based on THAT, you would need a w16x40 to get the stress and deflection down to an acceptable level.
The roof load is what kills. If you could find a way to convert them to trusses as someone else mentioned....it would take a MUCH smaller beam to 30' clearspan for only using a 1-ton hoist. You could actually drop that down to a w10x15 beam for the hoist.
That will be about a 450lb beam vs a 1200lb beam. And will be much cheaper.
Disclaimer: Dont bank on this advise. Its worth what you paid for it. I'm not there, I dont know your roof loads, or any other relevant information. This is just strictly a guess but to give you an idea what you are in for.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
198367 (A51243)
198367 (A51243)
2003 Sailfish 188 18ft. Boat with S/A Boat Trailer (A55853)
2003 Sailfish 188...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A56129)
2022 MACK GRANITE...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
