snowplow shoes on a rear blade setup??
   / snowplow shoes on a rear blade setup?? #11
I welded two pieces of pipe to the back of the blade, then added some shoes. Works great !
Sean
Thanks for the link. That is a good idea.
I went today to the local guy that sells snowplows and they were getting fifty bucks each for a shoe. forget that.
Will look at TSC pricing or the TSC horse mat idea over the weekend.
   / snowplow shoes on a rear blade setup?? #13
I think TSC-- or maybe it was a common mail order place-- was $20 or less.
   / snowplow shoes on a rear blade setup?? #14
I built a set of skids for my 5' back blade that bolt to the outer most bolts that hold the cutting edge on the blade.
If anyone is interested I will try to post a picture soon.
Good luck
   / snowplow shoes on a rear blade setup?? #15
If you are worried about it scratching your driveway I would get some poly ski shoes and fab a bracket that uses the cutting edge bolts to attach them.
   / snowplow shoes on a rear blade setup?? #16
If you have a welder you can make some fairly easy. This set I built for my box blade in the winter. Or any fab shop should be able to knock a set out for way cheaper than any store can sell em. Fab shops will have this kind of material laying around as mostly scrap to them.
   / snowplow shoes on a rear blade setup?? #17
First off. what is the condition of your blacktop driveway ? If it is in good shape dont worry about it, you will not hurt it..
20357 (A55758)
20357 (A55758)
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
