snowplow shoes on a rear blade setup??
   / snowplow shoes on a rear blade setup?? #11
I welded two pieces of pipe to the back of the blade, then added some shoes. Works great !
Sean
Thanks for the link. That is a good idea.
I went today to the local guy that sells snowplows and they were getting fifty bucks each for a shoe. forget that.
Will look at TSC pricing or the TSC horse mat idea over the weekend.
   / snowplow shoes on a rear blade setup?? #13
I think TSC-- or maybe it was a common mail order place-- was $20 or less.
   / snowplow shoes on a rear blade setup?? #14
I built a set of skids for my 5' back blade that bolt to the outer most bolts that hold the cutting edge on the blade.
If anyone is interested I will try to post a picture soon.
Good luck
   / snowplow shoes on a rear blade setup?? #15
If you are worried about it scratching your driveway I would get some poly ski shoes and fab a bracket that uses the cutting edge bolts to attach them.
   / snowplow shoes on a rear blade setup?? #16
If you have a welder you can make some fairly easy. This set I built for my box blade in the winter. Or any fab shop should be able to knock a set out for way cheaper than any store can sell em. Fab shops will have this kind of material laying around as mostly scrap to them.
   / snowplow shoes on a rear blade setup?? #17
First off. what is the condition of your blacktop driveway ? If it is in good shape dont worry about it, you will not hurt it..
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2023 DOUBLE DRUM ROLLER (A55745)
2023 DOUBLE DRUM...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2012 DOOSAN G25 GENERTOR (A55745)
2012 DOOSAN G25...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55314)
2012 Ford F-150...
