3-Point Hitch JD 2640 with1000rpm pto
   / JD 2640 with1000rpm pto #11
Jim,
I remember when the 2640 was introduced and had a 3020 at the time. Thought I wanted the newer 2640 being young the new stuff always seems more appealing. With hindsight being 20/20 which do you think was a better tractor overall? Looking back the 3020 seemed to be every bit as good as out 4020s'.
   / JD 2640 with1000rpm pto #12
With the Dubuques and Mannheims built for European and the North American markets. There was a variety of pto's . Hydraulic independent, two stage clutch live . Some even had a PTO disconnect way back on the left side of the transmission case . Farther back than the gear shift used with the two stage clutch.
So unless you check through the parts book, it isn't safe to say what the tractor maybe optioned with.
   / JD 2640 with1000rpm pto #13
Jim,
I grew up on a pair of late model 3020D's and wouldn't have traded them for anything Mannheim or Dubuque turned out.
   / JD 2640 with1000rpm pto #14
Could you reference this parts book for the 2640? I couldn't find anyting but the 540 and 540/1000 offerings for this tractor at JD parts online, I am curious about this.
   / JD 2640 with1000rpm pto #15
Yeah but when you are young the new stuff just seems better than a four year old tractor. Our 3020D with syncrorange had 15.5 38's, I could use that from time to time today. Great tractor in my book.
   / JD 2640 with1000rpm pto #16
b&d
As far as I remember all 3 cyl/4 cyl Dubuque/Mannheim tractors had the pto disconnect by LH heel while sitting in the seat. 6 cyl didn't have the pto disconnect on LH side
   / JD 2640 with1000rpm pto #17
Ours both came with 16.9x34's and one was later swapped out to 18.4x34's. Made a different tractor out of it. Did a decent job with an IH 720 4-18" plow.
   / JD 2640 with1000rpm pto #18
b&d
No left hand disconnect on my 1640.
Unless you check a parts book, the 40 series can be a real mix and match series. Half way through the 40's there was a serial number break and all production was moved to Mannheim.
   / JD 2640 with1000rpm pto #19
Don't know what tanget you are pursuing ? Go back and read my reply. I said go and check the parts book to see what the tractor may have been optioned with? Is that some sort of sin or mis-direction?
   / JD 2640 with1000rpm pto #20
Having a bad day?
Reread my post #7 where I did check JD parts online to werify that the 540 and 540/1000 were the only options available. I was curious if there was more information than contained in the online parts listings. If there is more information that would be good to know.
(INOP) 2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A57192)
(INOP) 2015...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2017 John Deere 5090GN (A53317)
2017 John Deere...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
Dump Truck Body with Tarp System (A55852)
Dump Truck Body...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
