Mahindra Battery Terminal Corrosion
   / Mahindra Battery Terminal Corrosion #11
Get the quality ends that are crimped on or soldered on. I solder these on, heat the end with a torch, melt solder in end, fill half way full, then insert wire into molten solder. Wear gloves and hold end with a vise grip. I also use large heat shrink tubing to seal connection. Install the felt washers on the post and spray the terminal with the thick red protective coating, this will outlast the cheap factory connections.
Dave
   / Mahindra Battery Terminal Corrosion #12
I had a similar issue with the negative side and I was able to just replace the whole short cable with a new one. Since your dealing with the positive side I think your only option is to replace the end.
   / Mahindra Battery Terminal Corrosion #13
Do you guys use battery maintaners?
My original untreated Mahindra battery lasted 9 years and corrosion was never a problem. I don't know if the maintainer had anything to do with it or not?? :confused3:
   / Mahindra Battery Terminal Corrosion #14
I use the cheap Harbor Freight float chargers on my tractor, and electric start field and brush mower. Both batteries seem as strong as they did 3-4 years ago.
   / Mahindra Battery Terminal Corrosion #15
My 3016 wouldn't start this weekend. Checked the battery and the terminal bracket was corroded away. The problem is the bracket is a think piece of metal instead of solid metal like car brackets. Dissapointing construction.
Sorry, but that's nothing more than a lack of maintenance.
   / Mahindra Battery Terminal Corrosion #16
Frequent checks of the battery is just as important as other tractor maintenance. Because mine is under the air filter container, it is hard to get a good look at it without a strong flash light. Those battery caps can vibrate loose, especially if they weren't firmly tapped down with a light instrument. I suggest looking at the battery, and cables, no less than once a month.
   / Mahindra Battery Terminal Corrosion #17
First tractor for me. Thought it would be similar to autos but Achingback is right. You need to check these cables more frequently. But I know the new cable I installed has a more traditional end which I don't think will ever corrode like the cheaper style they are using on everything now, even autos.
   / Mahindra Battery Terminal Corrosion #18
I used a generic connector on my 2615, worked fine.
   / Mahindra Battery Terminal Corrosion #19
My Nissan truck is almost 20 years old and has almost 260K miles on it and those exact same type battery terminals look like they did when I bought it new, just takes proper maintenance. My 4110 terminals are now 11 years old and on the 3rd battery and they are still in great condition too. The acidic gasses leak up around the posts on all batteries, some worse than others, that's why I use the little felts under the terminals on every battery of mine that I additionally soak in the spray protector and then spray the the whole post/terminal once it's complete. Been a pro mechanic for over 40 years now and this has ALWAYS worked for me. Grease is NOT good for this, it will eventually get between the terminal & post and cause connection problems. The spray stuff doesn't melt and get down between the terminal & post and will not give this problem. Have dealt with this on literally thousands of autos over the years. Permatex and CRC both make good spray protectants and a can will last for years ...
   / Mahindra Battery Terminal Corrosion #20
I did the same on my 2615 last year. I am on the original battery on a 2006 model.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
