Super UDT2, can I mix with my older SUDT ???
   / Super UDT2, can I mix with my older SUDT ??? #1
bellweather
Western MA
Kubota BX22
I ordered the newer Super UDT2 in preparation for my 300 hr service. Is it ok to mix with the earlier Super UDT I have?
Also, anyone know the volume of fluid required for A BX22?
Thanks
   / Super UDT2, can I mix with my older SUDT ??? #2
I ordered the newer Super UDT2 is preparation for my 300 hr service. Is it ok to mix with the earlier Super UDT I have?
Thanks
Not a problem to mix them. They are compatible. Not sure of the quantity you need. Check the owner's manual.
   / Super UDT2, can I mix with my older SUDT ??? #3
Bell,
My BX25 takes about 3 gallon 10 oz. with filter change. I would start with a click under 3 gallons and go from there. Better to under fill and add, then over fill and drain.
   / Super UDT2, can I mix with my older SUDT ??? #4
Bell,
A stanton, That is good advice.
   / Super UDT2, can I mix with my older SUDT ??? #5
Thanks
read the bottle and start at 3 gallons.
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2017 CATERPILLAR 320FL EXCAVATOR (A51242)
2017 CATERPILLAR...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
