Seafoam
   / Seafoam #351
I use it as much as I can. Gets costly with a lot of tires on the ground, especially where some of those are sitting more regularly. However there is a question I would like to ask. "Where do the contaminated particles go? My assumption is the exhaust system and or the lubricating oil.
Especially an engine like on my 8 n ford benefits in both oil and gas additives. They are always inside and regular maintenance really shines on them. Maintenance to me is the life of the vehicle.
   / Seafoam #352
water will head out the tail pipe..
   / Seafoam #353
What benefit with gasoline and oil additives? Does it have 10,000 hrs on the clock and makes 50% over factory rates power while burning no additional gasoline over stock
   / Seafoam #354
Not sure if this is covered but does it stabilize fuel for storage?
Anyone use it to clean diesel injectors?
   / Seafoam #355
Yes on both. Some fill new fuel filters with Sea Foam for faster results but I have not tried that.
DO NOT using it in the intake like on a gas engine.
Someone messed up a diesel engine doing that because it went into run away state. In that case they were lucky the best I remember it just bent the push rods and all was well after just replacing the push rods.
   / Seafoam #356
I am actually unclear of the request here so I will state my case for using Seafoam. m y two older fords rest for about 9 out of the twelve months inside an insulsted metal bldg. When they are mostly through for the year I service them prior to storage. Coolant, oil, hyd, battery, tire pres,etc. Top off or change as necessary. And without a doubt I add sea foam to all the fuel systems. The 8n in particular has a much cleaner fuel system as shown when I remove the sedement bowl from the shutoff valve. Another item I believe in is fluid film. This goes on all exposed hyd cylinders, exposed bolts,disc bearings, and most other moving parts. I can't speak for anyone else but to me these two products are worth it. One things for sure If I need my gear to roll it will be ready.
Thanks, Leonard
   / Seafoam #357
Thanks, Leonard
   / Seafoam #358
Thanks, Leonard
I like Seafoam, as I have already mentioned here, and I agree on Fluid Film. It is a bit pricey, but it is excellent. I like to spray it on exposed hydraulic chrome. I like to spray it on some hand tools that tend to rust (most don't, but some do.) I'd rather grab a handful of wool wax than a handful of oil.
   / Seafoam #359
I'm thinking if I mixed Fluid Film and Seafoam together I would have a universal fluid that would basically do anything.
Mike
(fan of both)
   / Seafoam #360
JUST FOR EVERYONES INFO, Seafom wont cure everything. I had a weedwhacker that I thought had a carb problem and used Seafoam in it. Ran it, let it soak in a 50/50 mix and no change. It cranked good, idled good but wouldnt rev up. I set it aside for about 8 months with the Seafoam in the tank. A couple days ago, I thought let me check that again. Still same issue, it cranked on second pull but still wouldnt rev up. I was going to a small engine repair place to get some saw parts so, why not take in the weed whacker.
Got it back yesterday and $27.50 later it runs like new. VERDICT: The engine had a fine screen (spark Arrestor? maybe) on the exhaust which was about half stopped up with carbon buildup. The shop completely removed the screen and now it runs great.
Just thought I would pass this tidbit along in case someone else has come across the same problem.
PS: The shop said that the carbon was from incomplete combustion due to running the engine at less than full throttle. I had been doing that quiet a bit when using a steel blade attachment for cutting sawbriars and other vines along an old fence line since many times I would be hitting hitting rocks and old wire among other immovable objects so I didnt want it turning full throttle.
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2018 KUBOTA SVL95-2S SKID STEER (A52705)
2018 KUBOTA...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
