Tractor mounted fork lift
   / Tractor mounted fork lift #11
Your pressure needs to go up to lift it faster. Basically, you're using full flow, but only building about half of what a normal hydraulic system pressure would be. A smaller cylinder would lift the load faster and still be under the normal operating pressure of 2000 to 2500 psi.
Nobody can tell you what your driving horsepower should be because we don't know your tractor weight or what kind of terrain you are operating on. For just driving around on flat land moving a 4000lb load, i'd guess 5hp assuming you have a hydrostatic transmission and can creep very slowly. I would not make a forklift attachment for a geared tractor. 8ft is too high to lift without making it really unstable from popping the clutch.
   / Tractor mounted fork lift #12
I'd be concerned about the sizing and construction of the counterbalance weight to make it safe too.....hp would have to factor in the additional weight to move the tractor (Tractor, counterbalance & load)
   / Tractor mounted fork lift #13
If this is a first time endeavor for chandra007 , not knowing anything about his mechanical skills, welding skills, electrical, etc, I believe he is in for a lot of trial and error, expense, and frustration.
It is one thing to just lift a load of 4000 lbs, and another to lift and move it over what kind of terrain.
How much does the machine weigh that the forklift will be attached to. Is counter balance requires, should the tires be solid, what size axle to handle that kind of load, is side shift necessary?
Will it be powered by battery, propane, gas, diesel. Lots of decision to make.
Do it yourself is fine as long as you have the time, money, and expertise in the areas necessary to build something like this.
If he builds something like he plans, and it doesn't go right, is he going to blame us?
   / Tractor mounted fork lift #14
Well somebody that can't do algebra is not qualified to design a forklift. I assume every thread like this is hypothetical because if he really wanted to do it he would hire a licensed engineer to do the design. He may just be using us for back of the envelope calculations. Anyone who would build a contraption like this without having a real engineer check their math, apply factors of safety, specify material types and treatments, define joint construction methods, and inspect the final product before use is taking their life and maybe others lives into their own hands.
Swick and JJ,
Both of you thinking in a different way,i am not using anybody for my calculations.I just mentioned give some idea ,if you know something.even though i am at starting stage,my interpretation must be useful for all.
sharing knowledge is allways good.
your words must be useful for all the members like me.
chandra007
   / Tractor mounted fork lift #16
Excerpt:
Cyl and roller chain.
Lifting Mechanism: Roller Chain Pulley
The hydraulic pistons are attached to the two main vertical structures called the "masts." However, the actual forks that carry the load are attached to the main body of the forklift through a pair of roller chain pulleys whose fulcrum is a gear at the top of the mast.
Thus, when the hydraulic pistons push the masts up, the gears on the masts push against the roller chains. Because one side of the chains are attached to the immobile frame of the forklift, the only way the masts can move up is if the gears rotate clockwise and pull the forks up.
The importance of this mechanism is that it allows the forks go far beyond the reach of the cylinders alone. If it weren't for the roller chain pulleys, forklifts would need much taller cylinders to lift loads to a comparable height. Taller cylinders would mean more building material, which would shift the vehicle's center of gravity forward and increase the risk of tipping. Likewise, taller cylinders would demand stronger pumps and higher pressure thresholds.
With a 4 in cyl and 2 in shaft, 48 in stroke, and if you have a 33 GPM pump at 3000 psi, the cyl will extend at 10.1 ips, and take about 4.752 sec to do it.
Cyl can push 37,699, or 18.84 T
A 2 in bore 1 in shaft, at 3000 psi can push about 9,425, or 2.71T
Now to power that 33 GPM pump, at 3000 psi will take about 68 HP.
   / Tractor mounted fork lift #17
As you can see from my photo the tractor is a good size and yet loaded with 1 tonne on the front flattens the tyres to some degree and even with power steering, turning is heavy. The tractor becomes light on the rear wheels and I used to put a heavy rotary hoe on the back to counter balance it. 4000 lbs would be better with solid tyres. You will need an equivalent counter weight on the other side of the front axle. This needs serious engineering with this weight.
   / Tractor mounted fork lift #18
A search of the forum will show that somewhere, some time ago someone bought an old fork lift carriage/mast and adapted it to his 3 point hitch.
As I recall it didn't work out too bad for him. That may be the way to go instead of asking all the algebra questions and as JJ points out, probably hit & miss fabrication.
I don't know where the OP is located, but I've seen old forklifts up for auction at Government Liquidation.
   / Tractor mounted fork lift #19
He says he is located in chennai, in south India.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
