J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
It does matter about the plumbing.
The pressure hose from the tractor must go to the IN port on the splitter valve.
The valve does have a relief, and should be adjusted to the same relief as the tractor.
With this valve, you can switch the work port hoses around to suit whichever way the cutting wedge is moving.
If the tractor is set to 2500 psi, the tractor will activate and this will limit the force on your log splitter as the valve used on the log splitter is set to 3000 psi.
That is a 6,283 lbs difference.
