Stump Grinder Build
   / Stump Grinder Build #11
brandoro said:
BaumaLight - Stump Grinders
I have one of these and am pleased with the operation. It really likes pine stumps and does well enough on fresh poplar stumps. Walks right through half rotten stumps. Not sure how handy it would be with a gear tractor but works nicely with the hst.
The one I have is the 1P/34. Not entirely clear where the link takes you. Simple design and cheapest by a significant margin. I don't have hundreds of stumps to grind so cheaper was important.
This is cool! Gravity feed! I thought there would be too much chatter to make this work. Thanks for the link. Now to make some drawings... ;-)
   / Stump Grinder Build #12
Just plug one of these into your hydraulics.
   / Stump Grinder Build #13
J_J did you build that?
   / Stump Grinder Build #14
J_J did you build that? What flowrate and pressure does it operate at?
Brandoro;
What size wheel did you go with... shows 24 and 34" on both models ? Also shows it could be used on a 20hp tractor. I don't know if it would work well on hardwood stumps with the limited hp unless one had alot of time.
JJ;
That machine would work best on a skid steer. Mine is only a 30hp model so I am going with the three point where I can use the 55hp available. Looks like it could use a couple more guards.. maybe its just me. Those cutter teeth look pretty aggressive.
   / Stump Grinder Build #16
Brandoro;
I see I screwed up on the numbers. The one I have is the 1P/24. That style, straight off the PTO without a gearbox only comes with the 24" wheel. That wheel does have 34 Teeth. I haven't had an opportunity to try it on hardwood, not much of that around here. Less power would slow it down some. Still faster than anything else I have tried. Chainsaw, axe, fire, letting it rot or digging it out with my little BH then having to fill the hole and deal with the stump/root ball. I know the extra power makes a difference with the chipper. On the B7610 I had before I could pull it down pretty good chipping birch, the B3030 won't slow down with anything I can poke down the chute.
   / Stump Grinder Build #17
I have found that hardwood grinds much easier than the pine, whitepine being the worsrt.
   / Stump Grinder Build #18
No sir. That stump grinder is a product of Power-Trac which builds a group of articulated hyd powered machines.
My machine can put about 24 HP into the hyd motor on the stump grinder. The larger machines can put about 35 HP in the stump grinder.
It is also an excellent trencher.
Here is their web page and some of the many attachments. Most being hyd powered.
Versatile Tractors,Compact Tractors,Trailer Packages,Landscaping,Utility Vehicle Rentals,Mowers-Power Trac
   / Stump Grinder Build #19
Those are pretty neat. Thanks for sharing. It reminds me of a steiner/ventrac if those companies would optimize their designs. I like that they are made of metal instead of plastic. They look easy to work on and very maneuverable
While buying some plate steel from the local steel yard I noticed they had some 1" x 23 3/4" round disks. Have no idea what they were cut for or how but the edge was as smooth as could be. The disk weighs 129# and would cost forty five dollars. Really wanted 3/4 or 5/8 but pickings are limited. Drilling this thick piece for cutters and hub will take a lifetime. Would this be worth the extra effort or Should I continue the search ? A wheel of this size / weight certainly would not require any down force . With good bearings it also would be hard to stop from operating speed. Lifting / moving this piece would also present a problem.
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
